Wire Size | 6 comments (6 topical, editorial)
Re: Wire Size (3.00 / 0) (#2)
by ghurd on Sun Sep 14th, 2008 at 10:11:08 AM MST
It is more like #7.
Compare the circular mill area.
Rule of thumb- double the wires, subtract 3.  (10-3=7)
Re: Wire Size (3.00 / 0) (#3)
by kittysmitty on Sun Sep 14th, 2008 at 05:52:36 PM MST
Yes, subtract 3, that was one of my calculations. #10 minus 3 is #4. Correct me if I am wrong, but I don't think odd numbers exist.
Re: Wire Size (3.00 / 0) (#4)
by Tritium on Sun Sep 14th, 2008 at 07:24:56 PM MST
Well I know #13, #15 and #17 exist in magnet wire. I think those are odd sizes. The formula subtract 3 means that 2 wires of #10 = 1 wire of #7.
Thurmond
Re: Wire Size (3.00 / 0) (#5)
by ghurd on Sun Sep 14th, 2008 at 10:27:00 PM MST
Odd doesn't matter.  I use #1 sometimes.
Not sure how you get 10 minus 3 is 4.
It looks like you are thinking about the wire diameter.
Two pieces of #10 would fit side by side, in the same hole as a piece of #4.
The empty space is not carrying current, so that area cannot be included.
"Compare the circular mill area."
The circular mils is the part that carries the current.  That's what is important.
The circular mils of #10 is about 10,000.
Two pieces of #10 will have about 20,000 circular mills, and that's about #7.
Four pieces of #10...
Two #10 is #10-3=#7, and two #7 is #7-3=#4.
It holds up as a quick rule of thumb.  #4 is about 40,000 circular mills, same as 4 x the 10,000 of #10.
Wire Size | 6 comments (6 topical, 0 editorial)
