Question on grounding? | 6 comments (6 topical, editorial)
Re: Question on grounding? (3.00 / 0) (#1)
by DanG on Tue Sep 16th, 2008 at 08:13:13 AM MST
The best store-bought lightning protection system may be the guarantee it's sold with...
http://www.dehn-usa.com/dehn-Application-Guides-pubcid1.html <-- their Lightning Protection Guide is a good read even if it is a showcase for 'their' components and worth the 16 megabyte download.
http://lecglobal.com/solutions/lightning/protection/ <-- another form of protection... Dissipation to prevent a static charge 'leader' from getting energetic enough to make the jump to full conduction.
The average lightning strike is 15,000-25,000 Amps so you want multiple methods in multiple areas to keep the direct strike out of your life.
Without spending as much for lightning protection as you did for the tower or wind turbine itself the best you can hope for is avoiding damage from a near-miss that saturates metal for hundreds of feet in all directions with high voltage surges. This has been posted on many times, use the google search function to see some of the best this group can come up with...(be sure to use the " -ungrounded " search term so Fieldlines user Ungrounded lightning Rod's posts don't clog the results (no offense ULR))
Re: Question on grounding? (3.00 / 0) (#5)
by DanG on Wed Sep 17th, 2008 at 01:04:35 PM MST
The issue of "Home Power" I got today has this question.
Roughly put, they recommend an arrestor in four places - top and bottom of tower and one just before the equipment being protected inside the building... plus one at the AC panel.
Sounds like good advice to me but I could never afford 'their' equipment.
Full Q&A text here:
http://www.homepower.com/article/?file=HP127_p12_ATE_1
Question on grounding? | 6 comments (6 topical, 0 editorial)
