holey stators batmam | 12 comments (12 topical, editorial)
Re: holey stators batmam (3.00 / 0) (#6)
by blueyonder (windwoodgood at yahoo dot co dot uk) on Sun Sep 7th, 2008 at 06:55:14 AM MST
 hi mau. you said writing late at night.
   then in the morning you read it again and wish you could edit it.
   yes i did think about other holes and things but i think i will
  have all the airflow i need for the time.
   dosent look like this will stall early  as cut in is a wee bit to high.
     maybe it will be ok.
    vanes built into the rotors will also help move air.
   so that's as far as i am going with air cooling for now.
 its time to move on a bit and start to look at the mast. with my back hurting so
  much  i am not looking forward to the heavy work.
   steel poles are heavy to play with.
    i need a sky hook.
holey stators batmam | 12 comments (12 topical, 0 editorial)
