The past summers progress | 10 comments (10 topical, 0 editorial)
Re: The past summers progress (3.00 / 0) (#5)
by Janne on Wed Sep 3rd, 2008 at 01:38:22 PM MST
(User Info) http://www.anotherpower.com/gallery/janne
Hi, thanks for the comments.
Roy, I'm located in Finland.
Flux, I also suspect that it is actually generating the 30A in lower winds than before, but it's hard to say for sure, as i don't have any kind of windspeed/power logging. For sure, it's now running better out of stall.
I didn't perfectly understand the ground failure part. It shouldn't ever be a problem, as the AXMKA4x16mm^2 aluminum cable is meant to be buried without any other protection. Stator circulating current heating should also not be a problem, as I'm rectifying all the 10 coils individually, if that is what you meant.
contact: #tuulivoima @ircnet or #otherpower @irc.otherpower.com
Re: The past summers progress (3.00 / 0) (#8)
by tecker on Wed Sep 3rd, 2008 at 04:45:04 PM MST
 Bringing all the coils down was a pain I'll bet but the flexabllity keeps other options open . Looks like you did your homework with your choice of home run wire . I was thinking the change in amperage might be due to a water filled conduit .
