Halfcrazy,
No inverter needed with induction motor, that is the beauty of this solution.
Motor must be running above name plate speed (RPM) as mentioned earlier.
For protection
Make sure system stops electrical output if the grid fails, and check for reverse power to keep grid from driving the motor as a motor if the lister quits, don't want to waste power! Unless starting it.
No Governor needed, the motor limits RPM to what it needs unless the Lister is more powerful than the motor. Make sure the lister is NOT more powerful than the induction motor.
Have fun,
Scott.
