http://tinyurl.com/3nwf8t <-- cooler description
The Stirling Cooler has been running fine for a couple of months now. Power consumption is around 600mA most of the time. I intend to improve ventilation around the box which will hopefully lower the consumption even more.
It has five temperature settings from 10 deg C (too warm) to deep freeze. I use the second fridge setting. I'm thinking of buying a second one to use as a freezer.
PS. The first generation of these were apparently rather noisy. Mine is audible, but no problem and I'm a noise sensitive person.
Owen If you're not living on the edge, you're taking up too much space.[ Parent ]
I forgot to say, mine was bought on clearance at a Coleman outlet near Detroit.
OwenIf you're not living on the edge, you're taking up too much space.[ Parent ]
