Once you let the speed rise with load the power capture goes way up and the stator loss goes down.
In theory with greater power extraction the thrust should be higher and it should furl at a lower wind speed.
It may be that the far increased power is obtained at so much lower wind speed that it didn't reach furling or it may be that the seeking force from the prop is increased by the higher prop speed.
Flux[ Parent ]
