5kw mornings amusement | 10 comments (10 topical, editorial)
Re: 5kw mornings amusement (3.00 / 0) (#6)
by Flux on Mon Sep 22nd, 2008 at 10:51:28 AM MST
Interesting point jimovonz, this does show how much the performance is compromised by dragging these things down to constant voltage and near constant speed.
Once you let the speed rise with load the power capture goes way up and the stator loss goes down.
In theory with greater power extraction the thrust should be higher and it should furl at a lower wind speed.
It may be that the far increased power is obtained at so much lower wind speed that it didn't reach furling or it may be that the seeking force from the prop is increased by the higher prop speed.
5kw mornings amusement | 10 comments (10 topical, 0 editorial)
