Calculating actual solar panel output? | 4 comments (4 topical, editorial)
Re: Calculating actual solar panel output? (3.00 / 0) (#1)
by Basil (basil(spamblock)key@bellsouth.net) on Sat Sep 20th, 2008 at 03:34:22 AM MST
I can tell you this mush. Tracking will let you get all you can out of your panels. ( Fast pay back )The best I have seen it 50 to 80 percent of the rating of a panel. I have a small system and I plan to keep adding. ( Just to have lights, a fan and so on when power goes out, ) I rate ever thing at half rating and that's with tracking. I'm sure you could search the board or net and find solar calculators.
Bad luck or none at all.
Calculating actual solar panel output? | 4 comments (4 topical, 0 editorial)
