Maintenance checkup prevents disaster | 13 comments (13 topical, editorial)
Re: Maintenance checkup prevents disaster (3.00 / 0) (#3)
by windspeed on Sun Sep 21st, 2008 at 02:33:25 PM MST
I use a similar shackle but it has the pin going through with a sprung split pin locking the other end.. very handy just pull out the split pin to release
maybe i am wrong but it looks like the anchors are not pointing towards the tower
Windspeed
Re: Maintenance checkup prevents disaster (3.00 / 0) (#4)
by Janne on Sun Sep 21st, 2008 at 02:52:53 PM MST
(User Info) http://www.anotherpower.com/gallery/janne
The anchor is perpendicular to the guy wire(actually about 100 degrees), it's a 16mm bar drilled 200mm into bedrock. This way the forces on the tower can newer pull the bar out from the bedrock.
contact: #tuulivoima @ircnet or #otherpower @irc.otherpower.com
Maintenance checkup prevents disaster | 13 comments (13 topical, 0 editorial)
