Alcohol Conversion | 12 comments (12 topical, editorial)
Re: Alcohol Conversion (3.00 / 0) (#9)
by tanner0441 on Tue Sep 23rd, 2008 at 12:35:26 PM MST
Hi
In the UK they came out of the factory with HS2 SU Carbs with AN needles. Removing the springs and filling the dashpots with brake fluid gave a faster throttle response.
Later we started fitting Nicky Carbs, they had a glass pannel in the float chamber.
Webber Carbs were very prone to freezing so on alchohol I think they would be a none starter. I have never seen throttle body injection on any A Series engine but I think you can get a retro fit multi-point.
The strongest A Series Engine was the 1071 Cooper engine, it had solid little ends and offset big ends, but before I get told off for going off topic I will shut up and again wish good luck with the project.
Brian
Re: Alcohol Conversion (3.00 / 0) (#11)
by frackers (g8ecj at *nospam* gilks dot org) on Wed Sep 24th, 2008 at 04:11:23 AM MST
That indeed takes me back - a Mk3 Sprite (1098cc) engine with the 12G295 Mk2 Cooper head ported according to the David Vizard instructions with a 211 cam, Mangoletsi long centre branch exhaust and a 45DCOE Weber carb. All running in a Morris 1000 Traveller 'Woody' of 1959 vintage. Had to scrap it when they stopped selling 101 octane fuel in the UK :-(
I found that to get the advance curve correct with the higher compression ratio I had to fit a Mk2 Cooper distributor body (the one without the vacuum advance) to get the right spring rates and bob-weights.
Dyno'ed at 75 BHP at the flywheel but now we're getting even further OT!!
Proper job!!
Re: Alcohol Conversion (3.00 / 0) (#12)
by zeusmorg on Wed Sep 24th, 2008 at 12:59:30 PM MST
 Actually years ago i built a fuel injection setup for my MG midget SCCA racer, i cast my own intake and used bosch components for the system. After tuning that was a very efficient setup! I added an oxygen sensor to the exhaust, and used a knock sensor type electronic ignition.
 The bugeye has the h1 carbs (1 1/4) so there are no springs on the piston to start with. I am quite pleased with the performance of them, of course I did re-build and re-bush them about 2 years ago.
Alcohol Conversion | 12 comments (12 topical, 0 editorial)
