Conversion resin | 7 comments (7 topical, 0 editorial)
Re: Conversion resin (3.00 / 0) (#7)
by luckeydog (bryan@coloradowindpower.com) on Fri Sep 26th, 2008 at 10:59:48 PM MST
(User Info) http://www.coloradowindpower.com
if you heat the resin and hardener separate to a little over 100f. it will thin out a lot .
you set up time will shorten quiet a bit. so if you can work fast before it goes thermal then it should wok for you well.
wind gens are much funner to watch than solar panels. Broomfield,Colorado
