Inverters | 15 comments (15 topical, editorial)
Re: Inverters (3.00 / 0) (#4)
by cdog on Thu Sep 25th, 2008 at 06:23:33 PM MST
Are there full size fridges using this method??
Cdog.
Re: Inverters (3.00 / 0) (#12)
by scottsAI (user name at eml dot cc) on Fri Sep 26th, 2008 at 01:05:22 PM MST
Cdog,
It helps if you reply to my post.
Here you replied to main story, not mine almost missed you were talking to me. (I think:)
Going back I see in 5jun08 you replied to a post of mine, except you replied to the main.
I normally do not reread stories. Thus will miss a post unless replied to mine.
I check for replies for a few weeks.
Not that I can find. Over the years I have seen many announcements, nothing in long term production except the Colman cooler.
Consider using the guts of the cooler and build a full sized fridge around it?
Would be a COOL project!-)
Need thick insulation 4 inch fridge and 6 for freezer, uses very little power.
For fun designed a 8x8 ft room freezer using chest freezer parts.
Required 6-8 inch insulation on all surfaces. Depends on assumptions.
Like some help with designing this project!?
Have fun,
Scott.
Re: Inverters (3.00 / 0) (#13)
by cdog on Fri Sep 26th, 2008 at 01:12:56 PM MST
Sorry I'm not so bright!!
Could a person simply put the guts of the cooler into an old fridge that has given up?
4" of insulation seems like a bunch.
I may try something like this if my new inverter doesn't do the trick, I'ts a good idea I think.
Sorry for mixing up postings,
Cdog.
Re: Inverters (3.00 / 0) (#14)
by scottsAI (user name at eml dot cc) on Fri Sep 26th, 2008 at 02:34:52 PM MST
Cdog,
You have to know about it before you can learn!
Now you know!
Yes, Good starting point. Make sure you understand which part goes inside and out.
Yep, then again, comes down to this choice:
One time spend money on insulation or forever spend more to run it?
Make sure the extra insulation will have a payback in a reasonable time.
Check out the couple existing off grid Fridges, similar thickness to get their low numbers.
As you have seen many ideas to reduce the cost, energy, equipment etc.
Let us know what your issues are, always good to show what you have found and why you need something else. The more you share the better we can help without telling your life story!-)
Have fun,
Scott.
Re: Inverters (3.00 / 0) (#15)
by wdyasq on Fri Sep 26th, 2008 at 09:29:45 PM MST
4" of urethane foam was minimum for refrigerators in boats. This would be closer to 7 inches styrofam. Freezers got more.
Inverters | 15 comments (15 topical, 0 editorial)
