Using river flow to pump water uphill (for later power generation) | 23 comments (23 topical, editorial)
siphoning (3.00 / 0) (#19)
by richhagen (richhagen (a t) Juno.com) on Sun Sep 28th, 2008 at 12:23:43 PM MST
Yes, you only have atmospheric pressure to work with.  When the force of gravity acting on the water exceeds that required to create a vacuum in you pipe, siphoning will not work.  This is about 33.9 feet or 10.3 meters at sea level.  Rich
Using river flow to pump water uphill (for later power generation) | 23 comments (23 topical, 0 editorial)
