36/38 dc volt generators | 2 comments (2 topical, editorial)
Re: 36/38 dc volt generators (3.00 / 0) (#1)
by thirteen on Sat Sep 27th, 2008 at 10:55:26 PM MST
I assume this is something you wish to take places and recharge your scooter. They can be made with direct drive to an altinator or as a belt driven altinator. Much of this would be determined by the size of the chain saw or altinator. You will need to find the rpms of the chainsaw and match the rpms needed for the altinator's best power output. Pulleys can be sized to aquire the needed speed for the altinator. You will need to build a guard to cover the belt. Using the same clutch system add a pulley to where the chain sprocket is. This will let you use it to cut wood by removeing the pulley portion. Check the voltage on the altinator and make sure the regulator is sized right. Just an idea. I used the leather shoelaces from my boots and put them on the chainsaw where the chain was.  I had left my lights on and had a dead battery up in the mountains. Ran my chainsaw to charge my battery. 1 hr later I had enough power to start my truck.
Re: 36/38 dc volt generators (3.00 / 0) (#2)
by arbela47000 on Sun Sep 28th, 2008 at 07:08:37 PM MST
One hour of chainsawing equivalent?  You must have gone through a lot of fuel.
I seems to me that for this scooter, it would work best to run it straight off the chainsaw powerhead.  The lowest-end Stihl (the 170) has 1.7hp.  It runs the chain through trees at about 45 mph, so I expect it could move a person pretty quickly.
36/38 dc volt generators | 2 comments (2 topical, 0 editorial)
