Onan 6.5nh propane conversion | 12 comments (12 topical, 0 editorial)
Re: Onan 6.5nh propane conversion (3.00 / 0) (#2)
by Rabrsniver on Sat Sep 27th, 2008 at 05:56:32 PM MST
Jason,
On second thought, maybe removing the diaphram from your high pressure reg. isn't the way to go.
Its been a while since I did my conversion. But the site I mentioned will steer you in the right direction.
John
Re: Onan 6.5nh propane conversion (3.00 / 0) (#3)
by Old F on Sat Sep 27th, 2008 at 06:52:15 PM MST
Here is a conversion I did a few years back
 http://www.fieldlines.com/story/2003/9/1/82526/70829
Old F
Re: Onan 6.5nh propane conversion (3.00 / 0) (#12)
by bgarrett on Tue Oct 14th, 2008 at 01:38:27 PM MST
Dave Sipes, did you use earthtubes for cooling?
You had posts2 years ago
I want to do this and need info
thanks  manyolkars at yahoo.com
Re: Onan 6.5nh propane conversion (3.00 / 0) (#6)
by jgnat1488 (jgnatow at yahoo dot com) on Sun Sep 28th, 2008 at 05:24:41 AM MST
The first regulator is the one from the forklift. Not sure of the btu but i figured they matched it for the lift so it should handle my little engine just fine. On the same note i did see a bbq regulator at tractor supply that was 100k btu, that should be enought to run a good size genny.
Jason Gnatowsky KG4FJC Buckingham, Va. "They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. "
