Onan 6.5nh propane conversion | 12 comments (12 topical, editorial)
Re: Onan 6.5nh propane conversion (3.00 / 0) (#7)
by jgnat1488 (jgnatow at yahoo dot com) on Sun Sep 28th, 2008 at 05:42:24 AM MST
Yes it is vaporrizor style regulator. It was hooked up to draw liquid. However I did some looking and most can run vapor just fine so long as the demand isnt too high. I run vapor threw out since i am only running at most 20HP, the regulator is rated for 85HP from liquid. It does shut off flow if no vacuum is "felt" kinda like a scuba regulator. The "mixer" sits just above the shaft for the choke and is how it senses vacuum. It only takes a very slight vacuum and it starts flow, too much and it shuts off flow allso. These regulators are really neat in how they work. I was worryied about getting the ratio correct so i installed a ball valve between the regulator and mixer, it turns out that the regulator does a real good job of that. The ball valve is fully open, if slightly closed the engine starts losing rpm. It handles 5000watt load fine so idont think i am too lean. Amount of fuel is controled by amount of vacuum so if the mixer was to be lower in the throat of the carb it should fuel richer, if raised it should lean out. I think i have it pritty close (accidently on purpose) :)
Jason Gnatowsky KG4FJC Buckingham, Va. "They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety. "
Re: Onan 6.5nh propane conversion (3.00 / 0) (#8)
by tanner0441 on Sun Sep 28th, 2008 at 11:56:39 AM MST
Hi
The vapourizer style regulator will have no problems with vapour, the problem could come in the bottle where the liquid becomes a gas, if it can't get enough heat back into the bottle, you will get a frost line round the bottle at the liquid level. Propane boiles at minus 44 C, and expands around 700 volumes.  At around 65C the tank pressure with no take off will be around 150PSI.
The carb adaptor can be a simple pipe entering the air flow anywhere above the narrow part of the choke tube, it is refered to as a spud adaptor, we used to drill through the side of the carb just below the air cleaner clamp.  Some vapourizers have a solenoid on the second stage to give a gas purge to assist in cold starting.  Air cooled engines had a vapourizer that was a concentric pipe that went into the exhaust.
There should be no problems with what you are trying to do and the engine life will be extended, propane is carbon deficient in its combustion so it will clean the engine, if you have trouble starting close the plug down 5 thou propane has a higher ignition temp, if the engine has points not electronic ignition it could eat the points more quickly, it has a slower flame front so there is a longer push on the piston so the bearings should last longer.
good luck
Brian
Re: Onan 6.5nh propane conversion (3.00 / 0) (#9)
by RandomJoe on Sun Sep 28th, 2008 at 01:08:49 PM MST
This reminds me of something that's been bugging me.  I had always thought running a generator on propane or natural gas would make it live longer, but when I was looking at generators to purchase earlier this year, I kept finding comments on the various websites (mostly dealers' sites, don't remember if I saw any on a vendor's site) clearly stating the opposite - that a generator run on propane or natural gas would have to be replaced sooner.  In some cases, considerably sooner!
So, why would they be saying that, when it seems fairly logical that it should live longer?  Or maybe I missed something - I was lumping propane/NG together, but only paying attention to NG since that's what I would have run.
Re: Onan 6.5nh propane conversion (3.00 / 0) (#10)
by tanner0441 on Sun Sep 28th, 2008 at 03:02:42 PM MST
Hi
If the engine has high carbon valve seats it can suffer damage to the seats, and rotory engines ie Wankel require fuel lubrication of the rotor tips, and suffer excessive wear of the tips.
As several generator companies offer LPG as an alternative fuel option, and CAT do an engine that will run on diesel, petrol, or various gasses by selecting the choice of fuel from the panel, but they are 12 ltr V12 not used in many RVs.
Generator manufacturers don't normaly go for high performance engines, 900, 1500, or 3000 depending on the number of poles, sorry in the US those RPM figures will be corespondingly higher.  I would have no hesitation in running a small domestic generator on LPG, add to the fact the exhaust gasses are mainly CO2 and water, the Nox products are minimal.
Hope this helps
Brian.
Re: Onan 6.5nh propane conversion (3.00 / 0) (#11)
by Ungrounded Lightning Rod on Tue Sep 30th, 2008 at 07:26:29 PM MST
... [propane] has a slower flame front ...
Sounds like it might be a good idea to advance the spark a tad, too.  More power and efficiency.
Onan 6.5nh propane conversion | 12 comments (12 topical, 0 editorial)
