Hugh Piggots 8 foot turbine - coil casting aspects | 4 comments (4 topical, editorial)
Re: Hugh Piggots 8 foot turbine - coil casting (3.00 / 0) (#4)
by David HK on Sun Sep 7th, 2008 at 11:57:00 AM MST
Thanks for the comment folks.
All points noted. I am planning to seal up the mould in every possible way with wax and release agent. I shall also follow Hugh's tip and put a bead of silicon around the top edges of the aluminium strip.
Will let you know how it progresses in due course.
David HK
Hugh Piggots 8 foot turbine - coil casting aspects | 4 comments (4 topical, 0 editorial)
