sensable outdoor solar lighting options? | 14 comments (14 topical, 0 editorial)
Re: sensable outdoor solar lighting options? (3.00 / 0) (#9)
by JamesJackson on Tue Sep 9th, 2008 at 09:10:34 PM MST
I've finally gotten all of the bits collected, so this is what I'm going to do.
I have 4 Amber LEDs (I don't want to use white - bugs collect around white lights).
I already have the solar panel (21-Watts) and the battery (17-Ah) - which is charged using a Morningstar Sunguard-4 charge controller.
I have my LVD (Low-Voltage Disconnect) boards - that also have an InfraRed (IR) switch built in.
Sooooooo... hooking it all together, I get an Amber porch light that puts out enough light to see the front porch at night - and doesn't attract bugs (I've already tested this bit).
When I drive up - I grab a handy IR remote controller - aim it at the IR sensor, and ZAP!! on go the lights! (using a handy IR pistol - as used in laser tag - I can get over 40 feet of distance)
Or - if I leave them on when I leave - and the battery depletes to the LVD drop-out level (it'd take many hours to do this... probably 8 or more), then the LVD controller will disconnect the battery - which of course turns off the light.
Anyway... there are many ways to achieve what you want to do. I say - try something - if you don't like it - re-examine the problem, and try a different approach.
Regards,
James Jackson
Oztronics
Re: sensable outdoor solar lighting options? (3.00 / 0) (#13)
by jclaudii on Thu Sep 11th, 2008 at 08:27:37 AM MST
Thanks everyone for the quick comments!
I didn't mean for this to get into a debate on cfl's or led's, but o-well when the technology is advancing at a decent pace.  I may have to "tinker" with some lighting solutions.  I know the x10 stuff has some things I can perhaps "adapt" to my design similar to the ir control.  I'm still thinking motion control would be the easiest way to control light on or off.  This would be coupled with an eye of course so it won't turn on during the day.  Not sure about the dump load yet.  I guess my first step is to obtain a solar panel of some sort.  I'll ask my dad back at the farm if he has any older fence chargers that "don't work" anymore that I could have.  I've got a few ups and alarm batteries that hold a decent charge that I use for hobbies and such.  I'll keep my options open about using 12v flourscent, but for the moment I'm thinking LED's are more scalable in light output vs run time.
Thanks again everyone.
Re: sensable outdoor solar lighting options? (3.00 / 0) (#14)
by ghurd on Thu Sep 11th, 2008 at 09:16:58 AM MST
Just a thought...
Lowe's has (had?) a 4 AA motion light with a daylight sensor. $13? Amer-Tack, but sometimes they are packaged with another name.
Replace the 4 AAs with an LM7806.
Replace the bulb with a mini relay or mosfet (the bulb is wired backwards, the tip is negative).
Use the relay or mosfet to trigger the other 12V lighting.
Make sure it has the daylight sensor.  The types without the daylight sensor waste a lot of power 24/7.
It looks like a tiny round solar panel on the top, maybe 3/8" dia.
Sometimes Lowe's has them that already have LEDs.  Would simply need to have a 6V system, or use the LM7806 to power it from a 12V battery.
