Yes half current , 1/4 the watts.
Apart from watching the diversion controller for not dumping enough current I think it will be ok. If you can reconfigure the turbine it will give you more power but you won't hurt anything.
Flux[ Parent ]
Yeah, even when you do this stuff "regularly" it can get confusing.
You got it in the end tho as others affirmed it is half the amps at half the volts and one quarter of the watts.
Good save!
Tom[ Parent ]
