http://www.thebackshed.com/Windmill/articles/PanelMeter.asp
If you have a old unused network card you can use the inverter to provide the isolated power.
Glenn http://www.thebackshed.com
thanks for the info! very nice explanation and diagram! i never knew that was on your site. your meter required 9 volts, so i see how you got that out of the computer chip/regulators/caps/ect. mine will work with anywhere from 7-30 volts. is there an easier way to get "isolated" power from my bank without having to adjust for voltage? i don't have mounds of old chips and electrical parts sitting around, but do have a radio shack close.
thanks birdhouse"let it blow, let it blow"[ Parent ]
I have one of the similar meters, wired for portability with some banana posts running off a 9 volt battery. {question everything, even if you think you understand it}[ Parent ]
