Making homemade stator wire? | 9 comments (9 topical)
Re: Making homemade stator wire? (3.00 / 0) (#2)
by willib on Sat Nov 07, 2009 at 10:38:04 AM MST
If you need wire , try a local alternator rebuild shop.
The guy close to me also rebuilds large starters, and with the large starters are worn out starter relays , which have  enamel coated wire (17ish gauge)in them. some is thicker if it is a really big relay.
if you are handy with a dremmel all you have to do is cut them open , five or ten mins with the cutting wheel.
above is a section of one of the stators i built , all with recycled wire.
The coils are 1 3/4 " dia
Bill
Carpe Ventum (seize the wind)
Re: Making homemade stator wire? (3.00 / 0) (#3)
by hiker on Sun Nov 08, 2009 at 01:06:23 AM MST
plastic covered wire works for a low powered alt.....
heres a few shots of one in progress..
   http://s153.photobucket.com/albums/s208/hiker_07/
WILD IN ALASKA
Re: Making homemade stator wire? (3.00 / 0) (#6)
by sticks22 on Tue Nov 10, 2009 at 10:03:25 AM MST
All good imfo! Thanks. I keep a look out for usable materials.
