Solar heater efficiency? | 11 comments (11 topical)
Re: Solar heater efficiency? (3.00 / 0) (#3)
by zap on Sun Apr 12, 2009 at 06:36:53 AM MST
Years ago I tested the efficiency of my panel filling a trash bag, similar to what Gary has on his site at http://www.builditsolar.com/References/Measurements/measurments.htm
With most bags it's hard to measure the exact volume so after doing the measurements a few times I ended up containing the bag inside a large cardboard box.  This made it easier to measure the volume.
I cut a flap in the box that would move out when bag filled up to let me know when to stop the time portion of the measurement.
The larger you make the bag and box, the more exact your measurements will be.
zap
Re: Solar heater efficiency? (3.00 / 0) (#4)
by jaskiainen on Sun Apr 12, 2009 at 07:33:20 AM MST
Yep!
The sun came up and i did that trash bag test.
I got 150 liters trashbag full in about 25 seconds. I tried to find some
converter to get it in ft/min, but came up with nothing.(Should it be cubic feet?)
Mainly because this very slow connection here. It's taking forever opening pages.
My test results are following:
Duct is 0.084539 sqft
Toutlet is 150F
Tinlet is 37F
Vair is 6 litres/second (a little help with this please)
I start to think that maybe I need a second pair of those blowers?
I even saw 174F coming out from it. Anyway I think it will do okay and survive with
or without those extra blowers. The area it should heat is about 2600 cubic feet.
Best regards jaskiainen
Re: Solar heater efficiency? (3.00 / 0) (#5)
by wdyasq on Sun Apr 12, 2009 at 10:20:12 AM MST
  1. liters = 5.29720001 cubic feet
  2. liter = 0.0353146667 cubic feet
HTH,
Re: Solar heater efficiency? (3.00 / 0) (#6)
by GaryGary on Sun Apr 12, 2009 at 04:16:58 PM MST
6 l/sec = 12.713 cubic foot/minute
A good site for doing conversions is: http://www.onlineconversion.com
So, your heat output is:
Qout = (air weight flow)(Tout - Tin) (Cair)
Qout = (12.71 ft^3/min)(0.065 lb/ft^3)(150F - 37F)(0.24 BTU/lb-F) = 22.4 BTU/hr or 1344 BTU/hour.
Don't know how large your collector is, but lets say its 20 sqft (you can adjust the calcs to the actual area of your collector).
Solar In = (300 BTU/sqft - hr)(20 sqft) = 6000 BTU/hr
Efficiency = (Heat out)(Solar in) = (1344 BTU/hr)(6000 BTU/hr) = 0.224 (22 %)
The 300 BTU/sqft -hr is for full sun, and for the collector being pointed right at the sun.  Its best to do this test around solar noon, and aim the collector right at the sun.
The temperature rise of 150 - 37 = 113F is a lot -- the collector could use more airflow for better efficiency.
How large is the collector?
Gary
Re: Solar heater efficiency? (3.00 / 0) (#7)
by jaskiainen on Mon Apr 13, 2009 at 01:59:54 AM MST
Hi
It hit me yesterday evening:
I just put some rough made fins inside the inlet and forgot they were there.
That I think cause some problems like overheating and much less airflow.
Like yesterday the panel outlet temp was 79 Celsius degrees.
A day before it was "only" 66 C.
So I think I need to fill my trash bag again?
Maybe it will fill within 15-20 seconds. Gonna do that test next weekend.
My panel surface is 3.2 squaremeters or 34.5 squarefeets.
It is solar can heater made out of 340 beercans with double glasing.
Inner is 2mm thick polycarbonate sheet and outer is 3mm acrylic sheet.
Two layers for better performance in winter.
Re: Solar heater efficiency? (3.00 / 0) (#8)
by GaryGary on Mon Apr 13, 2009 at 08:33:59 AM MST
So, with 34 sqft, ideally you would want around 68 cfm -- I think that's the problem.
Sounds like you may have found the solution.  You don't really have to get all the way up to 68 cfm, but I think you do want a lot more than 12 cfm.
With the beer cans, you should be getting a pretty even distribution of air through the collector as long as the manifold delivers air evenly to the can rows.
You can do a rough check on this by temporary taking off the glazing.  Let the collector stabilize in the sun with the fan on.  Measure the surface temps of the cans with one the IR gun style thermometers.  If you find fairly even temps that increase some for the intake end to the exit end, then the airflow in the cans is even and removing heat all over.  If you find hot spots, those are areas that are not getting enough airflow.  If you don't have the IR temperature gadget, you may be able to feel any hot spots just touching the surface with a finger.
How hard was it to measure the airflow with the plastic bag?  Does the bag technique seem to work pretty well?
Gary
Re: Solar heater efficiency? (3.00 / 0) (#9)
by jaskiainen on Mon Apr 13, 2009 at 10:42:16 AM MST
Plastic bag testing was kind of easy and it really is a simple technique.
I agree with the blower part. It should be a bit higher cfm. I will work on that later.
Taking off the glasing is not that tempting. I can get it off, but it's glued on.
So i prefer to keep it in place.
I'll keep you guys posted when i get my mind and on it again.
Re: Solar heater efficiency? (3.00 / 0) (#10)
by jaskiainen on Tue Apr 14, 2009 at 07:32:45 AM MST
Mind and hands...
