10' axial flux home made windmill | 12 comments (12 topical)
Re: 10' axial flux home made windmill (3.00 / 0) (#4)
by frackers on Sun Apr 05, 2009 at 02:39:08 AM MST
Excellent work - I really like the power splice box and the blade balancing detail. I balanced mine after I had the blades mounted and the bearing was a bit stiff when I first did it. After 6 months of flying it had slackened off enough to get it right and remove the shimmy!!
