The pdf user manual can be downloaded here:
http://www.brightgreenenergy.co.uk/cotek_inverters.asp
Your unit has a serial port for 2-way communication.
It is also different from most inverters that size in that neutral and ground are bonded during operation. If it overloads during startup then the most likely cause is a shorted FET.
Thanks. Actually there are 6 internal fuses -- all 10 amp where the line connects to the board. All were bad. I have them replaced which was a little bit of a pain.
All 6 fuses (automotive spade type) were not placed as easy removal. The spades of the fuses were soldered to the board! Rather than pull the board I soldered 16Ga wire to the new fuse spades and then to the remaining spades on the board. It is back up and operational! Nothing else in the inverter was damaged -- the fuses did their job.
I will continue to look into this to see if I can figure out what happened.
Thanks to all for the suggestions.
Scott O[ Parent ]
