My French is mostly limited to "Je prendrai le hamburger deluxe avec fromage", "Lebres le Blue", and "oo ee a'la rue o de plan?" And I'm from 1 county south of you, if you couldn't tell. :/ G-[ Parent ]
By gravity flow do you mean a convection loop powered by the raising of heated water and piping between the drums? I am not sure I get your point. Why not just siting the 2 drums close to the stove and rely on the convection loop within the drum?
Thanks for your helpEau, soleil, le vent[ Parent ]
I have seen some simple gravity fed systems that move heat from a wood (coal) stove to another area. Such as under the wash room floor to keep that room a little warmer.
I have also seen heat drawn from the (coal heated) hot water storage tank via air, fed into a wash room air vent to keep it warmer, and it works very well. Which is probably why the idea came to mind. G-[ Parent ]
