Steven,
Appreciate your taking the time to follow up on this.
In your drawing you show the gin as if it were only attached to one leg of the tower, if you look at the pics you'll see that there is ample metal between all the legs but you are correct in that the gin would be able to pivot on its pin given the opportunity.
What I'm going to do is build a plate to attach directly to the back 3 - 1 1/2" base plate studs that go down into the footing and mount the gin directly to the base plate behind the pin currently looking open. It's the pin for the third leg of the tower when it comes over and anchors.
As I mentioned this tower has been in use for a number of years and been up and down probably more than 20 times without incident. Perhaps it was a disaster in the making and I was just very fortunate that it all happened as it did????? I feel pretty happy that it happened in the cradle rather than on the way up, damn, I am lucky.
I was still hoping that some kind engineering/math knowledgeable person would help me out with some numbers on what kind of forces are REALLY at work here, I'd sure like to know?
Also, if you care to use it, my email is skipb@greatlakes.net perhaps that way I won't clutter the board with all my gibberish?
Thanks again,
Skip
