Please help me understand electrical power | 13 comments (13 topical)
Re: Please help me understand electrical power (3.00 / 0) (#6)
by rfrink on Thu Jul 02, 2009 at 07:07:57 AM MST
"The bottom line is the Lenz your working with is self limiting up the materials your using so you can let it fly if you can get an idea of the way the torque will effect the rotor."
Thank you for the note Tecker...can you explain a little more please..?
Re: Please help me understand electrical power (3.00 / 0) (#12)
by tecker on Fri Jul 03, 2009 at 07:28:21 AM MST
The size of the blades and the large front foil make the blades top out at 300 rpm or s (Check with Ed on his wind tunnel test )
Re: Please help me understand electrical power (3.00 / 0) (#13)
by rfrink on Fri Jul 03, 2009 at 10:48:00 AM MST
Yes, I see...got it. Thank you.
I'm not sure if it's good or bad...but that is one of the reasons why I choose the LenzII for my first try.
-Rob
