Author Topic: Small Wind Turbine Basics  (Read 9671 times)
kurt
    • website
« on: June 16, 2010, 08:03:18 PM »
this is a three part article that danf wrote a wile back covering the basics of wind power theory it covers power from the wind swept area etc. it is a must read for every newbie.
http://www.otherpower.com/windbasics1.html
http://otherpower.com/Gas/windbasics1.html  <=updated link
http://www.otherpower.com/windbasics2.html
http://otherpower.com/Gas/windbasics2.html <= updated link
http://www.otherpower.com/windbasics3.html
http://otherpower.com/Gas/windbasics3.html  <=updated link
there is allot more stuff in the links at the bottom of http://otherpower.com/  hours of good reading there.
SparWeb produced a very good .PDF file with plenty of information to get you started
http://www3.telus.net/faheydumas/Wind_Turbine/Forum/AXIAL_FLUX_HowItWorks.pdf
« Last Edit: November 16, 2015, 12:40:42 PM by Bruce S »
edingerb
Re: Small Wind Turbine Basics
« Reply #1 on: November 11, 2015, 02:08:16 PM »
Just getting started on the basics.
None of the links in this post work.  I have tried several times and on different days, but to no avail.
Do they need to be updated?
Frank S
« Reply #2 on: November 11, 2015, 04:08:09 PM »
Sometimes links as old as those will no longer work because either there has been a server change or the file has been deleted
edingerb
« Reply #3 on: November 16, 2015, 12:00:42 PM »
Let me rephrase.  Just getting started.  Since these links do not work, is there a way to read these articles at a different link?  If not, do you guys have something similar that has replaced them.
My main point being "just getting started."  I could spend hours and days asking questions and waiting for answers, some of which I have seen can be a little less than helpful ("You should read this or that post..."  I would rather gain a little knowledge first and then ask some questions, which, hopefully won't fall into the "that's so obvious it doesn't merit a serious response" category.
« Reply #4 on: November 16, 2015, 12:41:47 PM »
Try the updated links
edingerb
« Reply #5 on: November 16, 2015, 09:02:31 PM »
Thanks, Bruce.  Got them to load and am now reading up.
