Before I come out with very many details about the timer circuit, I'd like to get just a few more up and running in other systems.
There were countless glitches in the numerous versions leading up to this version, like TWO batches of bad parts (tried to save a $ during prototyping with ebay
) caused various failures that could not be narrowed down to a specific reason.
There should be a couple more up and running shortly.
It is a fairly simple circuit to understand.
Not so simple to actually build.
It is not much of a project for someone without experience soldering lots of parts on generic perf or vero board. Lots of 'stuff' to get in the right place for it to work correctly. Lots of stuff on 0.1" centers too. Lots of stuff to make mistakes in parts placement.
Between assembly mistakes, bad parts, etc, the timer circuit has been an ordeal.
Seemed simple when I started.
The 48V 'ghurd controller' circuit seems solid.
Apparently my concerns about what could go wrong were mostly unfounded.
Not many in use on real systems at the moment... because I still try to talk 48V guys into something a little fancier?
I would like to get a few more reports of perfect operation before saying it is good enough.
2 or 3 more 48V ghurd controllers should be up and running in the next 2 or 3 weeks.
