Author Topic: Active Pitchcontrol  (Read 240317 times)
XeonPony
  • Sanity is over rated!
Re: Active Pitchcontrol
« Reply #891 on: October 25, 2017, 06:34:39 PM »
The blade system and actuator will be the easy part it is the control is the hard part for me! going to be exciting getting the real unit made! Vs the air X
mbouwer
« Reply #892 on: October 26, 2017, 04:02:34 AM »
Suggestion:
Let us try first to improve the hardware parts for pitching.
And then show it to forum members with knowledge of control systems.
mbouwer
« Reply #893 on: October 27, 2017, 03:24:46 AM »
New magnet backing rings.
mbouwer
« Reply #894 on: October 27, 2017, 10:51:52 AM »
It would be nice to have a dialogue about scaling up to 300 mm outer diameter.
e.g with 51 Lamination packages 20 x 8 x 8   ( 17 per fase )
and 49 magnets 20 x 10  ( thickness 5 )
mbouwer
« Reply #895 on: October 30, 2017, 10:01:05 AM »
300 mm outer diameter magnet backing rings. Thickness 4 mm.
mbouwer
« Reply #896 on: November 01, 2017, 05:19:35 AM »
To glue together the sheets ( 20 x 8 mm ) of the 51 lamination packages I now want to make a mold.
What do you think of the size 20 x 8 (thickness 8 mm) of the packages,
compared to magnets 20 x 10 x 5 mm?
mbouwer
« Reply #897 on: November 04, 2017, 04:33:42 AM »
It is not so easy to figure out shape and size of the laminations, magnets and coils.
In the meantime, I would like to go on with a new axle and hub for the 300 mm. magnet backing rings.
XeonPony
« Reply #898 on: November 05, 2017, 12:18:20 PM »
Is it me or is this thread getting derailed from this project, probably be better in its own thread?!
mbouwer
« Reply #899 on: November 06, 2017, 02:03:29 AM »
My intention is to build on the Hugh Piggott design such as Midwoud showed in this topic (with active pitchcontrol)
And to get contacts and constuctive discussions with windmill friends.
XeonPony
« Reply #900 on: November 06, 2017, 11:46:25 AM »
yes I understand this but there is way to much fluf with nothing to do with the topic building up in here, yours is a very nice project and think better served if it was given it's on thread then link to this one for the pitch control parts.
Nothing personal just I been looking over this for the topic and just so much more messy now then what it was.
mbouwer
« Reply #901 on: November 06, 2017, 03:37:28 PM »
XeonPony,
Thanks for your comment. You're right.
Let us talk about active pitchcontrol in this topic.
Regards Rinus.
mbouwer
« Reply #902 on: December 01, 2017, 04:55:26 AM »
To attach the pitch control system I have threaded holes M4 at the back of the shaft.
mbouwer
« Reply #903 on: December 07, 2017, 07:26:29 AM »
Pitch bracket for guiding the threaded M 12 steering rod.
