I do not understand.. that there is not more attention or comments for this
This is THE one, which can really make everything possible, in small wind.
-Free parameters, to solve everything
-You do not need charge conrtroller of any kind ! If battteries full, blades go to Zero position, or keep the wanted voltage, for maintenance etc
-You do not need anykindof electronic clipper etc etc to on grid solution, to protect from overvoltage.
-Storm protection solved. You can have downwind, which I have foud very efficient, or with tail, no matter !
-You can adjust the pitch, if you want silent running..
-BEST
You can mount anykindof blades.
I have tested several extra thin with very high efficiency and oversized but gets
overspeed easily and noisy.
Now.. you can have max power all the time and in all conditions !
Etc
This solution could really make possible to have max power.
Are you speaking here just, to warm up.. or what.. ?
This is a really simple solution, after all, compared that robots have made us cars and electronics for centuries..
If we really want to make this wind power to happen, in our lifetime ?
Industrial made pitch control unit ?
That is a piece of cake.
Should cost a trillion part of a.., compared to anything
Lets start NOW !
Ps. I know.. next question is, what if..
It can be be solved.
If everything fails, there is a safety pin or other.. that will release the blades to zero position and it is released when electronics or power to the
pitch control unit is lost etc
Or with pitch conrol lose, or electronic controller lose, connects all the phases to short circuit.
Antero Rantanen
Finland
