Author Topic: ---SOLD--- F&P Stator and magnet drum plus mount for a HAWT ---SOLD---  (Read 1482 times)
F&P stator and hub along with a Randy's Workshop mount for a horizontal wind turbine. The mount uses a Yaesu thrust bearing(can buy from ham radio stores like DX Engineering, Gigaparts etc. I can get you links to them) to mount to the mast and has a swivel mount for the tail to turn it out of the wind. I have to much going on plus I cannot do the tower work I used to so getting this up is not an option. My back is getting worse so time to thin the project herd and concentrate on stuff I can do on the ground.
Asking $140+ actual shipping from 56237. It is large and heavy so it will be ~$50 or more I am betting.
Not in the picture but I have a pulley mount I was going to modify to use as a mount for the blades. It will need shimming and set screws added plus a plate made to mount the blades to. I will include that also(was $15 new)
« Last Edit: November 06, 2017, 02:29:54 PM by Bruce S »
Re: F&P Stator and magnet drum plus mount for a HAWT
« Reply #1 on: September 04, 2017, 01:08:59 PM »
$135 plus I have a 3 phase rectifier assembly for it.
« Reply #2 on: September 15, 2017, 04:46:06 PM »
$125, I need this gone!
XeonPony
  • Sanity is over rated!
« Reply #3 on: October 16, 2017, 12:22:51 PM »
How much for just the motor as I have every thing ells. and what is the stator wired for?
« Reply #4 on: October 16, 2017, 05:00:31 PM »
Will only sell as a package deal, stator is stock wiring
« Reply #5 on: October 18, 2017, 04:41:03 PM »
$100 want this gone!
XeonPony
« Reply #6 on: October 27, 2017, 09:33:58 AM »
Bought n payed for! sorry folks I got this one :) Will log results in the forum as it grows!
« Reply #7 on: October 27, 2017, 04:19:19 PM »
Yup sold!!
Have fun, all you need are blades, the bearing, and a tower to mount it on! Well and a blade mount... I included one I thought about using but it needs shimming to fit tight
XeonPony
« Reply #8 on: October 27, 2017, 07:59:06 PM »
well got a 22 foot tower to start, the bearing is at a scrap yard just need to pick it up along with two 9" disks at 1/2 thick of good steel! figured go with flange mounts on every thing 5 bolt pattern.
Can't wait!
« Reply #9 on: October 28, 2017, 07:27:50 PM »
The mount is designed to use a Yaesu Ham Radio tower thrust bearing GS-050... bolt on and for a 2" mast... Don't know if any other flange bearing will have that same bolt pattern 2.645" across or 1.865" on a side in a square pattern...
XeonPony
« Reply #10 on: October 28, 2017, 08:18:11 PM »
Nothing some cutting oil and a good array of drill bits won't fix! but I'll try and make the hub conform to the current lay out.
XeonPony
« Reply #11 on: November 06, 2017, 11:42:23 AM »
Stator arrived safe and sound and is in my hands! Can't wait to get it all set up and running thanks for the extra bits! they will be handy!
Re: ---SOLD--- F&P Stator and magnet drum plus mount for a HAWT ---SOLD---
« Reply #12 on: November 06, 2017, 04:51:07 PM »
Tossed in whatever I thought would be handy!
XeonPony
« Reply #13 on: November 07, 2017, 05:08:37 PM »
Any links to the tail boom set up and adjustment?
« Reply #14 on: November 08, 2017, 05:09:49 PM »
Not that I have found but it uses a similar offset design as the Other Power machines. Most use a 6' rotor diameter and from there you will have to calculate tail boom size and position... backshed may have info on it too...
