Homebrewed Electricity => Solar => Topic started by: petect on November 12, 2017, 07:06:29 AM
Title: PV questions for Mary
Post by: petect on November 12, 2017, 07:06:29 AM
Hi Mary  I followed your PV build closely and hope you donít mind a few questions. Iím planning on getting a ground mount system up this spring but will try to buy the panels shortly as it seems like prices might be going up due to possible increased tariffs.
As I recall your frame is pt lumber, Has that held up Ė any warping?
Did you add panels, if so were they all the same, if not any problems with mismatch?
I think you used 2 inverters ( I like that idea incase 1 goes down) . Did you run them into the same loads /battery banks, or do you have 2 separate loads?
Iím planning on about 3K in 24 v panels Ė stand alone. Iíll stay tied to the grid with proper/ code approved circuit separation, for large loads,  and long cloudy periods.  Batteries will hopefully go in not too long after the panels. And no, I donít expect a very efficient system or to see a payback, itís just something Iíve gotta do.
Thanks in advance for any help.
Pete
Title: Re: PV questions for Mary
Post by: Mary B on November 12, 2017, 05:12:39 PM
Wood frame is doing well but I added steel plates at all joiny=ts for extra strength.
I was able to get 4 more of the exact same panel so they are matched.
Each inverter sits on a common battery bank and then feeds separate loads, one feeds kitchen fridge and freezer(2 chest freezers with one as a fridge) the other feeds the meat chest freezer and my desk computer equipment.
If I did it again I would use a larger inverter, 1kw is borderline to start the freezer if the fridge is also running.
Post by: petect on November 13, 2017, 07:17:36 AM
Hi Mary
"If I did it again I would use a larger inverter, 1kw is borderline to start the freezer if the fridge is also running."    That is good to know!  Other than the 1K inverter being a bit light for your fridge/ freezer, how are the inverters and controllers holding up? \Are 2 mppt-45's adequate?
Thanks again
Pete
Post by: Mary B on November 13, 2017, 03:18:58 PM
Yes 2 MPPT 45's are plenty, I have never had one go in protect mode, using the relay controller they sell makes for a seamless install to switch inverters off as battery voltage drops. at 60% the fridge/small kitchen freezer drop back on grid, at 50% the big meat freezer and my computer drop back on grid(I run a UPS to filter that swap, there is a 30 second delay. On the fridge and freezer I don't worry, the delay lets the compressors bleed down plus the temp controller has a 3 minute power bump delay to keep from stressing the compressor).
To keep an eye on things I use a Lacrosse WS-09 fridge/freezer alarm/temperature readout. with 4 sensors I monitor the meat freezer, veggie freezer, keg fridge, and my pantry temps(I use my pantry as a fermentation chamber this time of year, temps drop below 60 I need to crack the door open and heat that room a bit).
Post by: petect on November 14, 2017, 04:07:57 PM
Mary
Thanks again. You have been VERY HELPFUL!
