Author Topic: composite structures  (Read 807 times)
« on: May 12, 2006, 07:15:14 AM »
a little epoxy on styrofoam with a matrix of carbon fiber anchored at both ends
anything around a couple of pounds that you want to see it hold up?
« Last Edit: May 12, 2006, 07:15:14 AM by (unknown) »
Re: composite structures
« Reply #1 on: May 12, 2006, 09:45:25 AM »
Willib,
In my younger years I used to build model aircraft. The wings were made out of styrofoam, covered by balsawood. This sandwich structure was VERY strong! A 2cm thick wing (strengthened in the middle, where the two wing-sections joined, with a bit of glassfiber and epoxy) could easily carry my weight (say, 50-60kg at the time). Impressive eh?
Don't see myself making a prop in the same way we used to make wings, but will surely follow your experiments with interest.
Peter.
« Last Edit: May 12, 2006, 09:45:25 AM by dinges »
« Reply #2 on: May 12, 2006, 10:21:17 AM »
hi Peter
this is the structure holding up a 32 fluid oz 946ml of resin
http://www.otherpower.com/images/scimages/2965/IM002078.JPG 71kb
the weight is 12.5N or 3.8lbs or 1.27kg
http://www.otherpower.com/images/scimages/2965/IM002079.JPG 67kb
« Last Edit: May 12, 2006, 10:21:17 AM by willib »
pickerol
« Reply #3 on: May 13, 2006, 02:38:43 AM »
Hi Wilib
Nice piece of work. If you apply fibre as a skin that attaches to the carbon and foam you'll have a piece as strong as hard wood. I used wooden spars for my blades and I can hardly believe the strength...and very light-weight...makes for easy balancing. With carbon I think you can end up with something super-strong. Did you make your matrix from folded carbon fibre? I really like the foam method. My 5' NACA double foam blade (with proper root!) drives my genny better than the old 6.5' triple PVC blade.
« Last Edit: May 13, 2006, 02:38:43 AM by pickerol »
« Reply #4 on: May 13, 2006, 11:14:34 AM »
" Did you make your matrix from folded carbon fibre?"
no , i just used two threads for the long ones , the threads are made up of a
ka-zillion strands
definition : a ka-zillion is way too many to possibly count
« Last Edit: May 13, 2006, 11:14:34 AM by willib »
