I found an old convection heater in a skip, rated at 3kW 240v. I've been looking for one of these to use as my dump load thinking it might have the bits I needed and when I got it apart I wasn't disappointed.
The uprights/spacers are ceramic. In the above picture I've stripped out most of the heating elements, just one remains, I thought I'd better take a photo before I went any further.
Ghurd sent me one of his charge controller kits, and gave me a lot of guidance. With his help I worked out what resistances I would need for my dump elements.
I did this by connecting one end of a wire coil to a lab power supply set at 14.5v and then finding how much wire gave me 3A current. This turned out to be around 72 turns of the existing element, about 5 inches. I then unwound a little bit of coil and counted another 72 turns. Using the two ends together as one terminal and the centre tap as the other, I now had two parallel resistors capable of 6A.
I mounted three of these doubles in a cut down piece of the heater chasis.
And added a 12v CPU fan to give a bit of extra air flow. At one end of the dump, all the 6 ends come to one terminal, at the other end you can see it's wired as three pairs.
Here the whole thing is mounted on a board.
You can see Ghurds charge contoller PCB at the bottom left. This little unit came with all the bits plus a few more, and even the heat shrink needed for the JFETs (even though I used some different stuff as I didn't have Ghurd's supplied stuff with me where I built it). It went together really well.
I know it's over-kill, but I put three JFETS in this each contolling 6A. This is partly through lack of knowledge and partly through lack of trust in components; I'd much rather have something running cool than hot. I'm trying to outwit Murphy here; it's just my luck that I'll get the highest winds ever experienced at my site on the day that I'm not there + the power is not being used + my furling is stuck!
This was only completed yesterday, so I haven't put it on the turbine yet. It also needs some diodes put over the resistors to deal with any stray inductance made by the coils. The unit is calibrated to begin dumping at about 14.3 volts.
Thanks to Ghurd for the kit and his help.
