Author Topic: First test of Hughs 4ft alt.  (Read 996 times)
« on: May 10, 2008, 02:59:46 AM »
I joined the alt and the prime driver test motor today. I did a few voltage test to confirm proper output for both star and "Jerry Rigged".
The #s are right on where they should be. Now I can add the fullwave bridge rectifiers and continue with all the other testing.
Here are a few pictures. First I brought the rpm up till the ac voltage per coil is 5v.
These are no load tests. Next I configured the alt star. Star produce 17.2 volts between any 2 connection of 3 phase.
"Jerry Rigged" produced 20 volts on any one of the phases.
Here are the pictures.
This is the 5 volt 1 coil.
This is the star reading.
This is the "Jerry Rigged" reading.
OK, Testing continues.
« Last Edit: May 10, 2008, 02:59:46 AM by (unknown) »
Re: First test of Hughs 4ft alt.
« Reply #1 on: May 10, 2008, 08:14:38 AM »
jerry,
using this construction method,
 how do you set the mag/ coil clearance.
on one of the photos there were a few paint stir sticks laying around.
i am guessing that you fix your stator tight to the speaker chassis and then set the rotor position using some spacers and then lock it in place with those collars?
« Last Edit: May 10, 2008, 08:14:38 AM by electrondady1 »
« Reply #2 on: May 10, 2008, 10:15:21 PM »
There are 2 alin set screws on the shaft to hub adaptor. I just slide the rotor to the desired position the tighten the set screws.
Yes the stator is secured to the speaker basket.
I did some no load DC voltage test today.
I ran the rpm up till one coil mesured 5 volt. This happened at 492 RPM.
In star at this RPM dc output is 22.5 volts. In "Jerry Rigged" the voltage is 25.5.
I think the real diferance will show up under load. There is a allmost sign wave shape on the scope.
« Last Edit: May 10, 2008, 10:15:21 PM by Jerry »
