Author Topic: pipe conections  (Read 1155 times)
97fishmt
pipe conections
« on: July 07, 2009, 09:55:02 PM »
Hi, I have had a hard time looking and looking at my tower sections
    the last couple of years and been trying to dream up the solutions
    to make it all work.
    Well, since work is a little slow right now I have had the time to get
    to it.  I came a cross a Rohn 45g at the salvage yard and bought
    it for scrap metal price.
    I knew I could make it work but my welding skills were not up to
    the task yet.  I got 5- 10' sections and a 9' tapered top
    for a total of 59'.  I think I paid about $250 for the lot.
    So, around the beginning of spring I got the tilting base done.
    Last week I came up with how to make the top work. (This is what
    I wanted to share.) The top is 2" od tube and only about 2' long coming
    out of the 3 legs.  I know the thing to do is just not use the top
    section and make an adapter for a mill. But I need to go as high as I can.
    O.K. I found using spring steel for a shim ( the spring in a broken
    tape measure) to go from 1 size to another, when going from tube to
    tube,  was the answer. It worked really slick.
    I found 5' of 1-3/4" od to go half way in the 2" with shimming top and
    middle and bottom. Then 6' of the same 2" tube over that. Nicely welded
    at mid section and where the shim was ( I made a little slot top and
    bottom).  Over that 2" pipe and then 2-1/2" pipe fit nicely.
    Now I feel good about what I have.  I thought the spring steel made
    the first connections very solid and a must for adding on to and
    adapting to pipe for the top section.
« Last Edit: July 07, 2009, 09:55:02 PM by (unknown) »
