Author Topic: Earth Cooling Tubes enough for summer time cooling??  (Read 2104 times)
clone477
« on: October 07, 2005, 05:14:10 PM »
I was curious if earth tubes are enough to cool a home in the summer??  I know it will not provide enough heat in the winter, but will help some.  My ground temps here in ontario are 8 degrees C, summer air temps regulary go 25-35 degree C.  If I run the proper length system, will it bring the house temps down significantly??  I like the closed loop system best, would seem more effiecent.  Thanks for any info.
« Last Edit: October 07, 2005, 05:14:10 PM by (unknown) »
clone477
Re: Earth Cooling Tubes enough for summer
« Reply #1 on: October 07, 2005, 11:28:00 AM »
I forgot to add a part to that question.  I found out the average ground temp here is 10C.  Does that mean that whether its -20C in winter or 35C in the summer the ground will always be within a couple degrees of 10C??  Or does it mean that the temperature of ground is taken every day of the year, and then averaged out??  Thanks
« Last Edit: October 07, 2005, 11:28:00 AM by clone477 »
