Author Topic: 12V heating element recommendations  (Read 11206 times)
jaybee
« on: September 08, 2005, 12:09:52 AM »
Hello,
I'm trying to look for 12V water heating elements for dumping excess charge into a hot water tank.
Would like to compare prices for various makes but have only found the one so far.
Any help would be appreciated.
« Last Edit: September 08, 2005, 12:09:52 AM by (unknown) »
Shadow
Re: 12V heating element recommendations
« Reply #1 on: September 07, 2005, 10:05:11 PM »
« Last Edit: September 07, 2005, 10:05:11 PM by Shadow »
jaybee
« Reply #2 on: September 08, 2005, 04:25:20 AM »
Thanks for that list. More to chose and they're cheaper.
Useful additional info as well.
« Last Edit: September 08, 2005, 04:25:20 AM by jaybee »
Drives
« Reply #3 on: September 08, 2005, 06:52:37 PM »
http://www.meci.com/Catalog/Category/351a1e14-68ea-4bf1-b992-9029fc6b6669
I have never purchased from these people, so I do not endorse them.  I just noticed that the prices looked good.
Remember the following formulas  Power (watts) = Volts X Amps  (in a DC circuit)
                                       Volts divided by Amps = Ohms (resistance)
For example, the first heating element rated 4500 watts at 208Vac can handle only 21.6 amps flowing through it.  It has a resistance of 9.6 ohms, and at 12 Vdc it will only draw 1.3 amps for a total wattage of 15 watts when used with a 12Vdc system.
Therefore, these immersion heaters would not work, but if you could generate high voltage DC with a Industrial PM motor, these would work well.
« Last Edit: September 08, 2005, 06:52:37 PM by Drives »
« Reply #4 on: September 09, 2005, 06:26:00 AM »
I have purchased items from them a time or 2. Seemed fine.
The 6000 watt should do a little better than the 4500 watt at lower voltage.
I wondered about the 12V 120w coffe cup heaters, like you see at flea markets for $3.  They look just like this expensive one.
http://www.3rivers.net/~cmac/k10.htm
« Last Edit: September 09, 2005, 06:26:00 AM by ghurd »
Laylow
« Reply #5 on: November 04, 2005, 09:24:54 AM »
Here is the cheapest place that I could find DC heating elements.  They are called SJH elements if you want to search for them but this was the only place I could find to buy them.  Their server was down just now but I bought one last week so I would imagine they are still there.
http://www.hydrogenappliances.com/hotwater.html
They had 12V, 24V, and 48V DC elements.  You could get 300 watts for $30 or 600 watts for $40.  I definately recommend the 600W.
Does anyone have any idea what happens if you use an AC element with DC or vice versa?  Or what about mixing voltages?
« Last Edit: November 04, 2005, 09:24:54 AM by Laylow »
Laylow
« Reply #6 on: November 05, 2005, 01:50:26 PM »
The site is back up.
« Last Edit: November 05, 2005, 01:50:26 PM by Laylow »
