Author Topic: Generators  (Read 1393 times)
SolidHydro
Generators
« on: January 27, 2005, 09:34:02 PM »
Who makes the most efficient generators? By this, I mean,...who makes the generators that require the least amount of hp. "Low Friction".
Are there frictionless?
Under full load, I'd like it to turn freely.
I do not want to require huge hp.
« Last Edit: January 27, 2005, 09:34:02 PM by (unknown) »
johnlm
Re: Generators
« Reply #1 on: January 29, 2005, 11:41:31 AM »
Im not sure what company makes the most effecient generators; however friction as I understand the definition is not a big issue.  I would define friction as the power losses in the bearings, which I suspect are likely less than 1% of the loss (or making it difficult to turn) in a generator.  I would guess many comercial generators / alternators are in the neighborhood of as low as 65% to as high as 90% effecient.  You say you want to use low horsepower.  How many watts do you want to generate?  Take that number and divide it by 746 and then divide that result by a typical effeciency of say 75% (0.75) to get the number of horsepower it will take to run the generator to get the output wattage you desire.  Low HP in = low wattage out.
« Last Edit: January 29, 2005, 11:41:31 AM by johnlm »
SolidHydro
Re: Generators
« Reply #2 on: January 30, 2005, 06:55:49 PM »
I understand that John, ....I should have stated "electromagnetic friction", bearing friction (cough), is the least of my concern.
For example, alternators are used over generators, because they require less hp. I am seeking an alternator which spins as freely as possible under load. It's application is irrelivant,... wind, hydro, engine, etc....
« Last Edit: January 30, 2005, 06:55:49 PM by SolidHydro »
