Author Topic: changing direction of light with water?  (Read 1698 times)
Derek
« on: May 03, 2007, 01:31:55 AM »
I seem to remember seeing something online about this.  They take a clear jug, and put a hole in the side near the bottom, then fill it with water.  Of course the water drains out in a slight arch out one side.  They took a laser, pointed it thru the opposite side of the jug towards the hole, and the laser stays within the water draining.  Therefore making the light actually do a 90 degree turn, due to angle of incidence I think?  Works the same as the fiber optic cables.  Light cant escape due to the angles and such.
Wondering if it'd be possible to transfer a great deal of infrared from something such as a fresnel lense.  Once a tracking system was worked out.  By constantly pumping water into the jug, you could have a consistent beam of infrared pointed downwards.  Would this work you think?
Sorry, I don't get the point? At all. Nothing topical for the board.
« Last Edit: May 03, 2007, 01:31:55 AM by (unknown) »
