Author Topic: 48 volt CFL's (Compact Fluorescent Lights)  (Read 6408 times)
David HK
  • Country: hk
« on: February 01, 2007, 08:35:46 AM »
The marketing people from Phillips Hong Kong have come back to me and advised that they have no plans to manufacture a 48 volt CFL in the immediate future.
The marketing people are not engineers and have little understanding of renewable energy and even less about battery banks and voltages.
I shall continue to make more enquiries and lobby suitable people who may be able to put pressure on the light bulb industry.
David HK
« Last Edit: February 01, 2007, 08:35:46 AM by (unknown) »
whatsnext
Re: 48 volt CFL's (Compact Fluorescent Lights)
« Reply #1 on: February 01, 2007, 07:23:39 AM »
Good luck but I can't imagine there will ever be enough market for someone like Phillips to get involved. If you really think there is one for this you may want to take advantage of it yourself. 48vdc CFL's would be an exceptionally small scale project.
JMO, John.........
« Last Edit: February 01, 2007, 07:23:39 AM by whatsnext »
David HK
  • Country: hk
« Reply #2 on: February 01, 2007, 03:02:22 PM »
Hello  JMO John.
The benefits of 48 volt CFL's would likely enable people to seriously consider 48 volt battery systems for renewable energy (RE) purposes. Other users of this site have suggested that they would welcome a product of this type.
The more choice there is in RE systems so much the better. Taking voltage direct from a battery bank seems to me at least far more beneficial than putting it through inverters because there are great savings in terms of cost and a reduction in equipment and so on.
To quote another user "The more volts there are, the easier it is to play with the electricity."
I would welcome more comments.
David HK
« Last Edit: February 01, 2007, 03:02:22 PM by David HK »
whatsnext
« Reply #3 on: February 01, 2007, 03:09:39 PM »
None of what you just wrote means anything to Phillips though and that is all that matters. For everyone who might want a 48vdc cfl someone will want a 36vdc or 60vdc. Phillips would never bother in a market where there is no standardization. Am I right in thinking that you are in Hong Kong? If you are you are in the correct location to do it yourself. There might be enough business for one guy to make a living at it. If there isn't there is no reason for a large company to even consider it.
John........
« Last Edit: February 01, 2007, 03:09:39 PM by whatsnext »
bob golding
« Reply #4 on: February 01, 2007, 05:01:52 PM »
hi david, why no try one of the chinese manufacturers. when i got in touch with one of them about 12v cfl,s with bayonet caps rather than es ones they were very helpfull. they had a mininum order of 100 which was very reasonable i thought.i can dig out the name if you are interested. email me. i used to work for philips and can tell you they wont consider such a limited market. they think in millions of dollars.
bob golding
« Last Edit: February 01, 2007, 05:01:52 PM by bob golding »
« Reply #5 on: February 01, 2007, 09:28:29 PM »
I know I could have them made.  But I would not want to!
The problem is volume.  With low production, the cost is high.  High cost is lower sales volume.
It would take a long time to sell only a few thousand pieces.
Like the 36V or 60V people,
Some people would want 7W, other people would want 11W, 13W or 23W.
Some would want a looped tube, some would want a twisted tube.
Some want North American bases, others want European bases.
Some want this Kelvin, some want that Kelvin...
It would tie up a lot of money in a bulb style or 2 that would have a very limited market.
I am not certain many 48V users are wired for using 48VDC loads.  I figure most 48V users are wired for an inverter to feed the loads.
« Last Edit: February 01, 2007, 09:28:29 PM by ghurd »
« Reply #6 on: February 13, 2007, 08:29:04 PM »
GE is making a 60Vdc CFL :)
They may not have intended too, but I was using it tonight :)
Check out the CFL post I will post in a couple mintutes, something like DC CFL?
« Last Edit: February 13, 2007, 08:29:04 PM by nothing to lose »
Hrdev
« Reply #7 on: January 13, 2012, 07:25:24 AM »
We are manufacturing 48VDC CFL Drivers for Industrail use  :)
« Reply #8 on: January 14, 2012, 12:35:12 AM »
Some companies are making them now.
You replied to a 4 year old post,
Hrdev
« Reply #9 on: January 14, 2012, 01:02:33 AM »
Ghurd
I joined this forum recently
I know this is four year old post
Just like to inform that we are manufacturing
This may help somebody in need  :)
Hrdev
