Author Topic: halogen fixtures  (Read 3414 times)
bobso
halogen fixtures
« on: February 15, 2007, 08:18:52 PM »
First post here.
I am putting in a lighting system for my business using 12V halogen bulbs with the two pins on back. The system is from batteries at 24V and I am going to wire the lights in pairs. Sound right?
I have no fixtures yet and was planning on making some up. If some are available at a reasonable price I would buy them.
Has anyone done this and are there some resources I can be directed to?
thanks,
bob
« Last Edit: February 15, 2007, 08:18:52 PM by (unknown) »
BT Humble
Re: halogen fixtures
« Reply #1 on: February 15, 2007, 03:05:23 PM »
It really depends on the type of business!  For instance, are you lighting a glass-case display area, or doing overhead lighting of shelving?  Do you want to use recessed-into-the-ceiling "down lights", or do you want track lighting that can be moved around?  Do you want lights on stalks that can be aimed, or will fixed-position units be satisfactory?
I'm afraid that with the information you've given so far it's very much a "How long is a piece of string?" answer.  I do want to help though! ;-)
BTH
« Last Edit: February 15, 2007, 03:05:23 PM by BT Humble »
bobso
« Reply #2 on: February 15, 2007, 03:22:22 PM »
sorry,
Overhead lights. There are fourteen foot ceilings so they will hang.
I've already got an idea for the shade/reflector part but was wondering how to make a two pin socket to hold the bulb.
Can you buy just the socket someplace?
thanks
« Last Edit: February 15, 2007, 03:22:22 PM by bobso »
whatsnext
« Reply #3 on: February 15, 2007, 03:30:59 PM »
just buy them at the hardware store assuming they have them where you are. I like halogens as they make a lot of specialty bulbs that may work perfect in your situation. I bought some 12 watters the other day and they put out a ton of light.
« Last Edit: February 15, 2007, 03:30:59 PM by whatsnext »
bobso
« Reply #4 on: February 15, 2007, 06:39:37 PM »
I already have the bulbs.
I am going to make the fixtures to hold the bulbs myself.
I am looking for sources to buy the little receptacles that the bulbs plug into.
I haven't seen them for sale anywhere including the hardware store.
« Last Edit: February 15, 2007, 06:39:37 PM by bobso »
bobso
« Reply #5 on: February 15, 2007, 09:43:16 PM »
whatsnext, maybe I owe an apology.
Did you mean they sell the sockets at Home Depot?
« Last Edit: February 15, 2007, 09:43:16 PM by bobso »
« Reply #6 on: February 16, 2007, 06:51:56 PM »
It sounds like you are talking about those 12 volt MR-16 bulbs
I made some fixtures for some of those bulbs, I bought the sockets from a local residential lighting store but Home depot may actually have them.
I made the fixtures from Muffler Adapter fittings. They adapted 2 inch to 1½ inch muffler pipes. Then drilled and tapped some holes for screws to hold the bulb in. Bent a metal strap to make the Yolk so the fixture could be mounted and aimed. This thing got pretty hot so I piled up some washers to act as a heatsink on the Yolk screws.
Heres a Pic . . .
« Last Edit: February 16, 2007, 06:51:56 PM by wooferhound »
bobso
« Reply #7 on: February 17, 2007, 11:45:19 AM »
Yes Woof they are MR16 and the nearest HDepot does not sell them.
BTW, are those cobwebs for diffraction?
Now that I know what they are called, I did a goog for mr16 and found them for two bucks ea. at superbrightleds.
thanks to all for the help, maybe I'll post a pic of my finished fixtures.
« Last Edit: February 17, 2007, 11:45:19 AM by bobso »
« Reply #8 on: February 17, 2007, 12:00:50 PM »
Home Depot, Lowes, etc. have tons of them.
Look for track light parts, sometimes low voltage yard and walkway lights.
The 'parts' selection is better in the store than online.
« Last Edit: February 17, 2007, 12:00:50 PM by ghurd »
bobso
« Reply #9 on: February 19, 2007, 09:47:18 AM »
That's what I hear but Sat. I drove 120 miles to the nearest home depot to find they didn't have any. Oh well, nice day for a drive!
Next time I'm in the big city I'll check out Lowe's.
thanks
« Last Edit: February 19, 2007, 09:47:18 AM by bobso »
