Author Topic: 12 inch aluminium magnet rotors  (Read 1558 times)
boblaporte
« on: March 04, 2007, 10:22:10 PM »
Hello,
Has someone in the group that has  results or opinions on using  aluminium for the stators to reduce weight. I am interested in the construction of the 10 foot wind system from Hugh Piggott. I have an 32 ft aluminium city light post that i will use as a post. It was damage froma car accident.I have cut out the bottom tube section and will re-weld  a new bottom  end with a hinge sytem. I tought using aluminium for the stator would not rust with the years ! Would this affect the speed on the blades,
Thak<s
bob
« Last Edit: March 04, 2007, 10:22:10 PM by (unknown) »
Re: 12 inch aluminium magnet rotors
« Reply #1 on: March 04, 2007, 05:05:07 PM »
The title says 12 inch magnet Rotors
The story talks about aluminum Stators
Don't use Aluminum for any of these two uses . . .
Aluminum in the magnet Rotors will not allow a complete magnetic Circuit which will reduce your potential output Voltage.
Aluminum in the Stator will cause Eddy Currents which will make so much drag that you will never make much power.
« Last Edit: March 04, 2007, 05:05:07 PM by wooferhound »
DanB
    • otherpower.com
« Reply #2 on: March 04, 2007, 07:06:03 PM »
Hi Bob -
yes - as woofer said, it'd be bad in both places.  You need steel behind the magnets (fairly thick steel) and you dont want aluminum in the stator for sure.
Curious about your user ID...  no chance you're in LaPorte Colorado is there?
« Last Edit: March 04, 2007, 07:06:03 PM by DanB »
beepipes
« Reply #3 on: March 04, 2007, 09:40:04 PM »
Or would that be LaPorte, Indiana?
Regards,
Pat
« Last Edit: March 04, 2007, 09:40:04 PM by beepipes »
GerryS
« Reply #4 on: March 05, 2007, 08:57:12 AM »
States with a city called Laporte:  Colorado, Indiana, Michigan, Montana, Ohio, Pennsylvania.
« Last Edit: March 05, 2007, 08:57:12 AM by GerryS »
