Author Topic: magnet question  (Read 791 times)
mikern
magnet question
« on: January 19, 2009, 06:16:43 AM »
What kind of results will I get if I use microwave magnets in building the 10ft windgen using the plans here at otherpower? thanks Mike
« Last Edit: January 19, 2009, 06:16:43 AM by (unknown) »
Re: magnet question
« Reply #1 on: January 19, 2009, 01:47:17 AM »
If you follow the plans you will get dreadful results if any at all.
You could probably adapt the alternator design to use microwave magnets but it would be large and heavy and would need lots more wire.
Just replacing the neos with microwave magnets would give you an alternator with a much higher cut in speed. It may produce something if you use the 48v stator on 12v but the thing will never be able to handle the intended power rating and the furling will not protect it so it would only work in a low wind area.
« Last Edit: January 19, 2009, 01:47:17 AM by Flux »
