Author Topic: Low Wind Permanent Magnet Alternator  (Read 4268 times)
Raptorman670
« on: March 30, 2009, 01:54:03 PM »
I thinking about buying this to make a wind generator. I live in PA and don't usually have a lot of wind but I want to use this for a 12 volt battery bank. Can you guys tell me if this is worth getting? This is a great site thanks for all the help.
            Dave  Here is the product http://www.windbluepower.com/Permanent_Magnet_Alternator_Wind_Blue_Low_Wind_p/dc-540.htm
« Last Edit: March 30, 2009, 01:54:03 PM by (unknown) »
Re: Low Wind Permanent Magnet Alternator
« Reply #1 on: March 30, 2009, 08:30:49 AM »
« Last Edit: March 30, 2009, 08:30:49 AM by ghurd »
Raptorman670
« Reply #2 on: March 30, 2009, 09:37:27 AM »
Hi G thanks for all your help I read those threads. I am confused lol. What would you think would be my best bet. Should I look for a Ametek 30vdc motor or get something else. Any suggestions.
         Dave
« Last Edit: March 30, 2009, 09:37:27 AM by Raptorman670 »
« Reply #3 on: March 30, 2009, 12:40:59 PM »
Myself, if I were you, at this stage,
I would learn to solder and get something else.
Maybe, after you think deeply about it, an ECM.
I am near 16148 zip.  You near there?
« Last Edit: March 30, 2009, 12:40:59 PM by ghurd »
Raptorman670
« Reply #4 on: March 30, 2009, 03:08:28 PM »
Hi G I live east about a hour away in Brookville. I know how to solder but not to much about electronics. I also looked at the Other Power's Low-RPM Disk Alternator. I was looking at something that isn't to complicated to build or buy. I don't have the money to pay for one completed like a thousand dollars or more. The ECM motors do you have to convert the power to DC. I have a few furnace motors 110 vac but do not know what I really need.
          Dave
« Last Edit: March 30, 2009, 03:08:28 PM by Raptorman670 »
adaml
« Reply #5 on: March 31, 2009, 06:14:13 AM »
Raptorman, think G linked to my post but will throw my two pence worth in if I may, might help?
I brought one, thought it was brilliant, then learnt a lot more and realised it wasn't at all!!  Learnt the hard and expensive way.  The thing is now "dead"!
I had a 30v Ametek in the shed and wished I had used that as a first project.  In my humble newbie opinion I think there are far better options and more fun than buying something "off the shelf".
Go with it if you will for a "quick fix" but be wary of the quoted output.
« Last Edit: March 31, 2009, 06:14:13 AM by adaml »
Raptorman670
« Reply #6 on: March 31, 2009, 12:47:46 PM »
Hi thanks Adam I think I am going to build a Low-RPM Disk Alternator. What sort of wind generator do you use? I can get the strut brake rotor assembly for almost nothing. I need to do a lot more reading.
             Dave
« Last Edit: March 31, 2009, 12:47:46 PM by Raptorman670 »
adaml
« Reply #7 on: April 01, 2009, 04:35:58 AM »
Raptorman, I am still tinkering with my first efforts at a motor conversion.  Personally I have found this far more rewarding than buying something off the net, learnt a lot in the process to.  There are some pictures in my files you may find interesting?
I do not know enough to attempt building my own from scratch, nor do I have the need.  I like the smaller mills that I can get to charge my 12v batteries then put that charge to use, it is at my current (limited) level of understanding.  Lots of reading on here on motor conversions, I would suggest looking for "Jerry's" posts, personally I have found them to be a wealth of information - even if I don't (yet) understand it all!!
Good luck.
« Last Edit: April 01, 2009, 04:35:58 AM by adaml »
