Author Topic: Power calculation  (Read 812 times)
newind
Power calculation
« on: April 07, 2009, 01:36:18 AM »
Does this formula apply across the board? ie; typical 3 blade turbines vs vertical turbines? I got it from the AWEA site.
Thanks,
new guy.
Wind Turbine Power:
    P = 0.5 x rho x A x Cp x V3 x Ng x Nb
where:
P = power in watts (746 watts = 1 hp) (1,000 watts = 1 kilowatt)
rho = air density (about 1.225 kg/m3 at sea level, less higher up)
A = rotor swept area, exposed to the wind (m2)
Cp = Coefficient of performance (.59 {Betz limit} is the maximum thoretically possible, .35 for a good design)
V = wind speed in meters/sec (20 mph = 9 m/s)
Ng = generator efficiency (50% for car alternator, 80% or possibly more for a permanent magnet generator or grid-connected induction generator)
Nb = gearbox/bearings efficiency (depends, could be as high as 95% if good)
« Last Edit: April 07, 2009, 01:36:18 AM by (unknown) »
electronbaby
    • Windsine.org
Re: Power calculation
« Reply #1 on: April 06, 2009, 07:43:45 PM »
yes, it should work for both types. Be careful when calculating the Cp with drag based props.
« Last Edit: April 06, 2009, 07:43:45 PM by electronbaby »
Have Fun!!!  RoyR KB2UHF
newind
« Reply #2 on: April 07, 2009, 08:21:10 PM »
Thanks.
« Last Edit: April 07, 2009, 08:21:10 PM by newind »
