Author Topic: Decimals to fractions  (Read 15751 times)
Ronnn
    • Myspase profile
« on: January 31, 2010, 02:48:16 PM »
 A reasonably priced drill press has more end play in the quill that the difference between 0.86 and whatever the nearest fraction would be in sixty-fourths. We are working in wood at this stage of the game. I checked in the home brew book and could not find a conversion chart for decimals to fractions. Ok I get 1.75, but how about a hint.... 0.86 equals......?  0.61 equals.....? Thanks for the help.
« Last Edit: January 31, 2010, 02:48:16 PM by (unknown) »
Ronnn
    • Myspase profile
Re: Decimals to fractions
« Reply #1 on: January 31, 2010, 02:55:40 PM »
I did the 86 over 100 math and 43/50 makes me feel somewhat like bevis or butthead. I should have asked for a drill bit size I can buy at a hardware store. Remember when people who worked there new stuff?
« Last Edit: January 31, 2010, 02:55:40 PM by Ronnn »
mettleramiel
« Reply #2 on: January 31, 2010, 03:01:23 PM »
.86 as a fraction only reduces to 86/100 and therefore, does not work out evenly into 64ths. If that's what you want, though, all you have to do is multiple .86 by 64, giving you 55.04/64. Close enough for me!
« Last Edit: January 31, 2010, 03:01:23 PM by mettleramiel »
« Reply #3 on: January 31, 2010, 03:03:23 PM »
This is pretty basic math. Never seen a "chart' myself but it may exist.
1/8" is.125"
1/16" is 0625"
The rest should be easy basic adding or multiplying.
Some decimal values will not be a sensible fraction you will find on a tape measure.
Best I can do is give you the info to sort it out.
And there it is.
« Last Edit: January 31, 2010, 03:03:23 PM by TomW »
Ronnn
    • Myspase profile
« Reply #4 on: January 31, 2010, 03:10:29 PM »
I'm begining to see the light. It doesn't look like there is a good way to express that number on a regular ruler. I'll pass on the drill bit tho. It would cost alot, guess I need a ruler with decimals on it.
« Last Edit: January 31, 2010, 03:10:29 PM by Ronnn »
freejuice
« Reply #5 on: January 31, 2010, 04:15:48 PM »
the closest to .086 in 64ths would be 5/64ths, which is .07812
 now you can creep a little bit close to the number if you go 32nds. So 3/32 is .09375
 You might know this but to convert to metric just remember the magic number 25.4
 Lets say you want to convert 3/8ths of an inch ( or in decimel.375)to metric
 just take .375 (always convert your fractional tolerence to a decimel) and multipy by 25.5 ...whic gives us 9.525mm
To go from metric to decimel just divide by 25.4...Lets say we need to drill or ream a hole to 11.11 mm, but all we have is fractional stuff laying around and need to hit the hole as close as we can.
 We take 11.11 divded by 25.4 which gives us .4374, which is just one-ten thousandths off from 7/16ths of an inch which is .4375 sometimes conversion is our best friend!
 Here's a quick and dirty fractional to decimel chart:
Eights
1/8 0.125
1/4 0.250
3/8 0.375
1/2 0.500
5/8 0.625
3/4 0.750
7/8 0.875
Sixteenths
1/16 0.0625
3/16 0.1875
5/16 0.3125
7/16 0.4375
9/16 0.5625
11/16 0.6875
13/16 0.8125
15/16 0.9375
Thirty-seconds
1/32 0.03125
3/32 0.09375
5/32 0.15625
7/32 0.21875
9/32 0.28125
11/32 0.34375
13/32 0.40625
15/32 0.46875
17/32 0.53125
19/32 0.59375
21/32 0.65625
23/32 0.71875
25/32 0.78125
27/32 0.84375
29/32 0.90625
31/32 0.96875
Sixty-fourths
1/64 0.015625
3/64 0.046875
5/64 0.078125
7/64 0.109375
9/64 0.140625
11/64 0.171875
13/64 0.203125
15/64 0.234375
17/64 0.265625
19/64 0.296875
21/64 0.328125
23/64 0.359375
25/64 0.390625
27/64 0.421875
29/64 0.453125
31/64 0.484375
33/64 0.515625
35/64 0.546875
37/64 0.578125
39/64 0.609375
41/64 0.640625
43/64 0.671875
45/64 0.703125
47/64 0.734375
49/64 0.765625
51/64 0.796875
53/64 0.828125
55/64 0.859375
57/64 0.890625
59/64 0.921875
61/64 0.953125
63/64 0.984375
 All the best,
 Gavin
« Last Edit: January 31, 2010, 04:15:48 PM by freejuice »
freejuice
« Reply #6 on: January 31, 2010, 04:26:35 PM »
decimal equivalent, multiply mm times .03937. For exact mm equivalent, multiply decimal times 25.4.
Drill Bit Decimal Equivalency Chart
Fraction, Decimal Decimal
Number or Metric Equivalent Equivalent
Letter Size Size (in.) (mm)
BITS
BLADES
58 0.0420 1.067
57 0.0430 1.092
1.10 0.0433 1.100
1.15 0.0453 1.150
56 0.0465 1.181
3/64 0.0469 1.191
1.20 0.0472 1.200
1.25 0.0492 1.250
1.30 0.0512 1.300
55 0.0520 1.321
1.35 0.0531 1.350
54 0.0550 1.397
1.40 0.0551 1.400
1.45 0.0571 1.450
1.50 0.0591 1.500
53 0.0595 1.511
1.55 0.0610 1.550
1/16 0.0625 1.588
1.60 0.0630 1.600
52 0.0635 1.613
1.65 0.0650 1.650
1.70 0.0669 1.700
51 0.0670 1.702
1.75 0.0689 1.750
50 0.0700 1.778
1.80 0.0709 1.800
1.85 0.0728 1.850
49 0.0730 1.854
1.90 0.0748 1.900
48 0.0760 1.930
1.95 0.0768 1.950
5/64 0.0781 1.984
47 0.0785 1.994
2.00 0.0787 2.000
2.05 0.0807 2.050
46 0.0810 2.057
45 0.0820 2.083
2.10 0.0827 2.100
2.15 0.0846 2.150
44 0.0860 2.184
2.20 0.0866 2.200
2.25 0.0866 2.250
80 0.0135 0.343
0.35 0.0138 0.350
79 0.0145 0.368
0.38 0.0150 0.380
1/64 0.0156 0.396
0.40 0.0157 0.400
78 0.0160 0.406
0.42 0.0165 0.420
0.45 0.0177 0.450
77 0.0180 0.457
0.48 0.0189 0.480
0.50 0.0197 0.500
76 0.0200 0.508
75 0.0210 0.533
0.55 0.0217 0.550
74 0.0225 0.572
0.60 0.0236 0.600
73 0.0240 0.610
72 0.0250 0.635
0.65 0.0256 0.650
71 0.0260 0.660
0.70 0.0276 0.700
70 0.0280 0.711
69 0.0292 0.742
0.75 0.0295 0.750
68 0.0310 0.787
1/32 0.0312 0.792
0.80 0.0315 0.800
67 0.0320 0.813
66 0.0330 0.838
0.85 0.0335 0.850
65 0.0350 0.889
0.90 0.0354 0.899
64 0.0360 0.914
63 0.0370 0.940
0.95 0.0374 0.950
62 0.0380 0.965
61 0.0390 0.991
1.00 0.0394 1.000
60 0.0400 1.016
59 0.0410 1.041
1.05 0.0413 1.050
Copyright 2004 Robert Bosch Tool Corporation. All rights reserved.
3.90 0.1535 3.900
23 0.1540 3.912
5/32 0.1562 3.967
22 0.1570 3.988
4.00 0.1575 4.000
21 0.1590 4.039
20 0.1610 4.089
4.10 0.1614 4.100
4.20 0.1654 4.200
19 0.1660 4.216
4.30 0.1693 4.300
18 0.1695 4.305
11/64 0.1719 4.366
17 0.1730 4.394
4.40 0.1732 4.400
16 0.1770 4.496
4.50 0.1772 4.500
15 0.1800 4.572
4.60 0.1811 4.600
14 0.1820 4.623
13 4.70 0.1850 4.700
3/16 0.1875 4.762
12 4.80 0.1890 4.800
11 0.1910 4.851
4.90 0.1929 4.900
10 0.1935 4.915
9 0.1960 4.978
5.00 0.1969 5.000
8 0.1990 5.054
5.10 0.2008 5.100
7 0.2010 5.105
13/64 0.2031 5.159
6 0.2040 5.182
5.20 0.2047 5.200
5 0.2055 5.220
5.30 0.2087 5.300
4 0.2090 5.309
5.40 0.2126 5.400
3 0.2130 5.410
5.50 0.2165 5.500
7/32 0.2188 5.558
5.60 0.2205 5.600
43 0.0890 2.261
2.30 0.0906 2.300
2.35 0.0925 2.350
42 0.0935 2.375
3/32 0.0938 2.383
2.40 0.0945 2.400
41 0.0960 2.438
2.45 0.0965 2.450
40 0.0980 2.489
2.50 0.0984 2.500
39 0.0995 2.527
38 0.1015 2.578
2.60 0.1024 2.600
37 0.1040 2.642
2.70 0.1063 2.700
36 0.1065 2.705
7/64 0.1094 2.779
35 0.1100 2.794
2.80 0.1102 2.800
34 0.1110 2.819
33 0.1130 2.870
2.90 0.1142 2.900
32 0.1160 2.946
3.00 0.1181 3.000
31 0.1200 3.048
3.10 0.1220 3.100
1/8 0.1250 3.175
3.20 0.1260 3.200
30 0.1285 3.264
3.30 0.1299 3.300
3.40 0.1339 3.400
29 0.1360 3.454
3.50 0.1378 3.500
28 0.1405 3.569
9/64 0.1406 3.571
3.60 0.1417 3.600
27 0.1440 3.658
3.70 0.1457 3.700
26 0.1470 3.734
25 0.1495 3.797
3.80 0.1496 3.800
24 0.1520 3.861
For exact decimal equivalent, multiply mm times .03937. For exact mm equivalent, multiply decimal times 25.4.
Drill Bit Decimal Equivalency Chart (cont'd.)
BITS
BLADES
2 0.2210 5.613
5.70 0.2244 5.700
1 0.2280 5.791
5.80 0.2283 5.800
5.90 0.2323 5.900
A 0.2340 5.944
15/64 0.2344 5.954
6.00 0.2362 6.000
B 0.2380 6.045
6.10 0.2402 6.100
C 0.2420 6.147
6.20 0.2441 6.200
D 0.2460 6.248
6.30 0.2480 6.300
E 0.2500 6.350
6.40 0.2520 6.400
6.50 0.2559 6.500
F 0.2570 6.528
6.60 0.2598 6.600
G 0.2610 6.629
6.70 0.2638 6.700
17/64 0.2656 6.746
H 0.2660 6.756
6.80 0.2677 6.800
6.90 0.2717 6.900
I 0.2720 6.909
7.00 0.2756 7.000
J 0.2770 7.036
7.10 0.2795 7.100
K 0.2810 7.137
9/32 0.2812 7.142
7.20 0.2835 7.200
7.30 0.2874 7.300
L 0.2900 7.366
7.40 0.2913 7.400
M 0.2950 7.493
7.50 0.2953 7.500
19/64 0.2969 7.541
7.60 0.2992 7.600
N 0.3020 7.671
7.70 0.3031 7.700
7.80 0.3071 7.800
7.90 0.3110 7.900
5/16 0.3125 7.938
8.00 0.3150 8.000
O 0.3160 8.026
8.10 0.3189 8.100
8.20 0.3228 8.200
P 0.3230 8.204
8.30 0.3268 8.300
21/64 0.3281 8.334
8.40 0.3307 8.400
Q 0.3320 8.433
8.50 0.3346 8.500
8.60 0.3386 8.600
R 0.3390 8.611
8.70 0.3425 8.700
11/32 0.3438 8.733
8.80 0.3465 8.800
S 0.3480 8.839
8.90 0.3504 8.900
9.00 0.3543 9.000
T 0.3580 9.093
9.10 0.3583 9.100
23/64 0.3594 9.129
9.20 0.3622 9.200
9.30 0.3661 9.300
U 0.3680 9.347
9.40 0.3701 9.400
9.50 0.3740 9.500
3/8 0.3750 9.525
V 0.3770 9.576
9.60 0.3780 9.600
9.70 0.3819 9.700
9.80 0.3858 9.800
W 0.3860 9.804
9.90 0.3898 9.900
25/64 0.3906 9.921
10.00 0.3937 10.000
X 0.3970 10.084
10.20 0.4016 10.200
Y 0.4040 10.262
13/32 0.4062 10.317
Z 0.4130 10.490
Drill Bit Decimal Equivalency Chart (cont'd)
BITS
BLADES
10.50 0.4134 10.500
27/64 0.4219 10.716
10.80 0.4252 10.800
11.00 0.4331 11.000
7/16 0.4375 11.112
11.20 0.4409 11.200
11.50 0.4528 11.500
29/64 0.4531 11.509
11.80 0.4646 11.800
15/32 0.4688 11.908
12.00 0.4724 12.000
12.20 0.4803 12.200
31/64 0.4844 12.304
12.50 0.4921 12.500
1/2 0.5000 12.700
12.80 0.5039 12.800
13.00 0.5118 13.000
33/64 0.5156 13.096
13.20 0.5197 13.200
17/32 0.5312 13.492
13.50 0.5315 13.500
13.80 0.5433 13.800
35/64 0.5469 13.891
14.00 0.5512 14.000
14.25 0.5610 14.250
9/16 0.5625 14.288
14.50 0.5709 14.500
37/64 0.5781 14.684
14.75 0.5807 14.750
15.00 0.5906 15.000
19/32 0.5938 15.083
15.25 0.6004 15.250
39/64 0.6094 15.479
15.50 0.6102 15.500
15.75 0.6201 15.750
5/8 0.6250 15.875
16.00 0.6299 16.000
16.25 0.6398 16.250
41/64 0.6406 16.271
16.50 0.6496 16.500
21/32 0.6562 16.669
16.75 0.6594 16.750
17.00 0.6693 17.000
43/64 0.6719 17.066
17.25 0.6791 17.250
11/16 0.6875 17.462
17.50 0.6890 17.500
45/64 0.7031 17.859
18.00 0.7087 18.000
23/32 0.7188 18.258
18.50 0.7283 18.500
47/64 0.7344 18.654
19.00 0.7480 19.000
3/4 0.7500 19.050
49/64 0.7656 19.446
19.50 0.7677 19.500
25/32 0.7812 19.845
20.00 0.7879 20.000
51/64 0.7969 20.241
20.50 0.8071 20.500
13/16 0.8125 20.638
21.00 0.8268 21.000
53/64 0.8281 21.034
27/32 0.8438 21.433
21.50 0.8465 21.500
55/64 0.8594 21.829
22.00 0.8661 22.000
7/8 0.8750 22.225
22.50 0.8858 22.500
57/64 0.8906 22.621
23.00 0.9055 23.000
29/32 0.9062 23.017
59/64 0.9219 23.416
23.50 0.9252 23.500
15/16 0.9375 23.812
24.00 0.9449 24.000
61/64 0.9531 24.209
24.50 0.9646 24.500
31/32 0.9688 24.608
25.00 0.9843 25.000
63/64 0.9844 25.004
1 1.0000 25.400
« Last Edit: January 31, 2010, 04:26:35 PM by freejuice »
DanB
    • otherpower.com
« Reply #7 on: January 31, 2010, 06:13:31 PM »
So long as we've got all this other good info.. just in case you're working with circles here's PI, to a few digits, enough to get your calculations close anyhow:
3.14159265358979323846264338327950288419716939937510
58209749445923078164062862089986280348253421170679
82148086513282306647093844609550582231725359408128
48111745028410270193852110555964462294895493038196
44288109756659334461284756482337867831652712019091
45648566923460348610454326648213393607260249141273
72458700660631558817488152092096282925409171536436
78925903600113305305488204665213841469519415116094
33057270365759591953092186117381932611793105118548
07446237996274956735188575272489122793818301194912
98336733624406566430860213949463952247371907021798
60943702770539217176293176752384674818467669405132
00056812714526356082778577134275778960917363717872
14684409012249534301465495853710507922796892589235
42019956112129021960864034418159813629774771309960
51870721134999999837297804995105973173281609631859
50244594553469083026425223082533446850352619311881
71010003137838752886587533208381420617177669147303
59825349042875546873115956286388235378759375195778
18577805321712268066130019278766111959092164201989
38095257201065485863278865936153381827968230301952
03530185296899577362259941389124972177528347913151
55748572424541506959508295331168617278558890750983
81754637464939319255060400927701671139009848824012
85836160356370766010471018194295559619894676783744
94482553797747268471040475346462080466842590694912
93313677028989152104752162056966024058038150193511
25338243003558764024749647326391419927260426992279
67823547816360093417216412199245863150302861829745
55706749838505494588586926995690927210797509302955
32116534498720275596023648066549911988183479775356
63698074265425278625518184175746728909777727938000
81647060016145249192173217214772350141441973568548
16136115735255213347574184946843852332390739414333
45477624168625189835694855620992192221842725502542
56887671790494601653466804988627232791786085784383
82796797668145410095388378636095068006422512520511
73929848960841284886269456042419652850222106611863
06744278622039194945047123713786960956364371917287
46776465757396241389086583264599581339047802759009
94657640789512694683983525957098258226205224894077
26719478268482601476990902640136394437455305068203
49625245174939965143142980919065925093722169646151
57098583874105978859597729754989301617539284681382
68683868942774155991855925245953959431049972524680
84598727364469584865383673622262609912460805124388
43904512441365497627807977156914359977001296160894
41694868555848406353422072225828488648158456028506
01684273945226746767889525213852254995466672782398
64565961163548862305774564980355936345681743241125
15076069479451096596094025228879710893145669136867
22874894056010150330861792868092087476091782493858
90097149096759852613655497818931297848216829989487
22658804857564014270477555132379641451523746234364
54285844479526586782105114135473573952311342716610
21359695362314429524849371871101457654035902799344
03742007310578539062198387447808478489683321445713
86875194350643021845319104848100537061468067491927
81911979399520614196634287544406437451237181921799
98391015919561814675142691239748940907186494231961
56794520809514655022523160388193014209376213785595
66389377870830390697920773467221825625996615014215
03068038447734549202605414665925201497442850732518
66600213243408819071048633173464965145390579626856
10055081066587969981635747363840525714591028970641
40110971206280439039759515677157700420337869936007
23055876317635942187312514712053292819182618612586
73215791984148488291644706095752706957220917567116
72291098169091528017350671274858322287183520935396
57251210835791513698820914442100675103346711031412
67111369908658516398315019701651511685171437657618
35155650884909989859982387345528331635507647918535
89322618548963213293308985706420467525907091548141
65498594616371802709819943099244889575712828905923
23326097299712084433573265489382391193259746366730
58360414281388303203824903758985243744170291327656
18093773444030707469211201913020330380197621101100
44929321516084244485963766983895228684783123552658
21314495768572624334418930396864262434107732269780
28073189154411010446823252716201052652272111660396
66557309254711055785376346682065310989652691862056
47693125705863566201855810072936065987648611791045
33488503461136576867532494416680396265797877185560
84552965412665408530614344431858676975145661406800
70023787765913440171274947042056223053899456131407
11270004078547332699390814546646458807972708266830
63432858785698305235808933065757406795457163775254
20211495576158140025012622859413021647155097925923
09907965473761255176567513575178296664547791745011
29961489030463994713296210734043751895735961458901
93897131117904297828564750320319869151402870808599
04801094121472213179476477726224142548545403321571
85306142288137585043063321751829798662237172159160
77166925474873898665494945011465406284336639379003
97692656721463853067360965712091807638327166416274
88880078692560290228472104031721186082041900042296
61711963779213375751149595015660496318629472654736
42523081770367515906735023507283540567040386743513
62222477158915049530984448933309634087807693259939
78054193414473774418426312986080998886874132604721
56951623965864573021631598193195167353812974167729
47867242292465436680098067692823828068996400482435
40370141631496589794092432378969070697794223625082
21688957383798623001593776471651228935786015881617
55782973523344604281512627203734314653197777416031
99066554187639792933441952154134189948544473456738
31624993419131814809277771038638773431772075456545
32207770921201905166096280490926360197598828161332
31666365286193266863360627356763035447762803504507
77235547105859548702790814356240145171806246436267
94561275318134078330336254232783944975382437205835
31147711992606381334677687969597030983391307710987
04085913374641442822772634659470474587847787201927
71528073176790770715721344473060570073349243693113
83504931631284042512192565179806941135280131470130
47816437885185290928545201165839341965621349143415
95625865865570552690496520985803385072242648293972
85847831630577775606888764462482468579260395352773
48030480290058760758251047470916439613626760449256
27420420832085661190625454337213153595845068772460
29016187667952406163425225771954291629919306455377
99140373404328752628889639958794757291746426357455
25407909145135711136941091193932519107602082520261
87985318877058429725916778131496990090192116971737
27847684726860849003377024242916513005005168323364
35038951702989392233451722013812806965011784408745
19601212285993716231301711444846409038906449544400
61986907548516026327505298349187407866808818338510
22833450850486082503930213321971551843063545500766
82829493041377655279397517546139539846833936383047
46119966538581538420568533862186725233402830871123
28278921250771262946322956398989893582116745627010
21835646220134967151881909730381198004973407239610
36854066431939509790190699639552453005450580685501
95673022921913933918568034490398205955100226353536
19204199474553859381023439554495977837790237421617
27111723643435439478221818528624085140066604433258
88569867054315470696574745855033232334210730154594
05165537906866273337995851156257843229882737231989
87571415957811196358330059408730681216028764962867
44604774649159950549737425626901049037781986835938
14657412680492564879855614537234786733039046883834
36346553794986419270563872931748723320837601123029
91136793862708943879936201629515413371424892830722
01269014754668476535761647737946752004907571555278
19653621323926406160136358155907422020203187277605
27721900556148425551879253034351398442532234157623
36106425063904975008656271095359194658975141310348
22769306247435363256916078154781811528436679570611
08615331504452127473924544945423682886061340841486
« Last Edit: January 31, 2010, 06:13:31 PM by DanB »
Tritium
« Reply #8 on: January 31, 2010, 07:31:09 PM »
DanB,
I am too lazy to count so to how many decimal places did you calculate Pi ?
Thurmond
« Last Edit: January 31, 2010, 07:31:09 PM by Tritium »
Fused
« Reply #9 on: January 31, 2010, 09:36:18 PM »
« Last Edit: January 31, 2010, 09:36:18 PM by Fused »
freejuice
« Reply #10 on: February 01, 2010, 02:12:28 AM »
Dan, LOL!
  Looking back on it,I think it would have just been better if I had just done this, intead of all that cutting and pasting....sorry guys:
http://www.imperialinc.com/pdf/I_DrillSizeDecimalEquivalent&TapDrillChart.pdf
« Last Edit: February 01, 2010, 02:12:28 AM by freejuice »
Ronnn
    • Myspase profile
« Reply #11 on: February 01, 2010, 11:58:13 AM »
Dang Dan, talk about a shcolarly reply..... I thank you verbosely. I felt guilty after my post to you guys and did some more looking around on the web instead of working on my wife's pot rack and came to this conclusion. 7/8ths  [ .875 ] seems pretty close to .86 so if I fudge the line on the negative side I should be ok. I imagine the width of a slightly dull pencil mark is probably close to the difference between the two numbers.
 Since we are hand winding on a hand built winder with naturally varying amounts of tension why would the you guys pick such a critical number? No two hand wound coils are going to be exactly the same tension or have the same resistance if you measure out to the hundredths of an ohm. Especially on a digital ohm meter. My Fluke 87 changes it's mind every .3 seconds. No that my self supporting rationalizations are over....
Is there some reason I should not use 7/8's and 21/32's? That is the question.
Thanks to everyone for the very useful tables. I'm saving them all to my solar/building folder. That's where the wind stuff lives too. I can not see all the other posts in this thread from this reply screen.
« Last Edit: February 01, 2010, 11:58:13 AM by Ronnn »
bj
« Reply #12 on: February 02, 2010, 07:26:41 AM »
Nice one Dan, I think I'll print that for future reference.
« Last Edit: February 02, 2010, 07:26:41 AM by bj »
bj
Lamont AB Can.
DanB
    • otherpower.com
« Reply #13 on: February 02, 2010, 09:00:08 AM »
I am not sure specifically which dimensions you're referring to. I often mix up decimals and fractions when talking about drill sizes and such.
Regarding the coils - the number of turns is pretty critical, you can be off a bit one way or the other and... who knows for sure, it might work better!
Regarding measuring resistance with your fluke meter... with coils and stators you can kind of forget about that.  Perhaps a 48Volt stator has high enough resistance that you could measure it, but generally the resistance in these is so low that a normal ohm meter isn't useful -resistance in the leads, and even how hard you press the leads against the copper is significant.
I wouldnt worry about measuring resistance in coils, so long as the number of turns is about right, and the wire gauge isright it should work fine.  If you want to measure the finished stator, perhaps the best way is to hook it to a power supply, (or a battery) and measure voltage and current.
Another good way to estimate resistance (if you're sure you got it hooked up right) is simply weigh it.  From there you can use a wire gauge chart if you know the gauge of wire, and the weight... to determine resistance.
« Last Edit: February 02, 2010, 09:00:08 AM by DanB »
Ronnn
    • Myspase profile
« Reply #14 on: February 02, 2010, 11:11:21 AM »
Hey Dan, my concern was the dimensions for the pins [nails] we wind the coils around. Specifically, how much rounding up or down to the nearest fractional equivalent from 0.86 and 0.61, would effect the physical distance between the coils on the stator and their performance. It doesn't seem like it would matter if it was close to the decimal figure. But the numbers used were pretty precise for wood working so I want to be sure it's ok to fudge a little.
« Last Edit: February 02, 2010, 11:11:21 AM by Ronnn »
dbcollen
« Reply #15 on: February 15, 2010, 08:33:35 AM »
I counted, 7500
Dustin
« Last Edit: February 15, 2010, 08:33:35 AM by dbcollen »
