Author Topic: 60 watts at 110 rpm?  (Read 798 times)
gotwind2
  • ben[at]gotwind.org
« on: October 14, 2009, 02:40:32 PM »
This is a Chinese built alternetor I believe - bare with me..
All is explained in this eBay advert along with videos (youtube), appologies for external links but neccesary.
http://tinyurl.com/yzt53e2
Hand cranked (100 rpm maybe) in the video powering a 50 watt bulb.
What's inside the thing to generate that kind of power at such low revs?
« Last Edit: October 14, 2009, 02:40:32 PM by (unknown) »
gotwind2
Re: 60 watts at 110 rpm?
« Reply #1 on: October 14, 2009, 02:43:37 PM »
I suspect someone will bin this.
However here is a direct video link to what I am enquiring about.
http://www.youtube.com/watch?v=q1lC9eN0u60&feature=player_embedded
« Last Edit: October 14, 2009, 02:43:37 PM by gotwind2 »
« Reply #2 on: October 14, 2009, 04:02:11 PM »
Nothing, I suspect. That looks like a 12v halogen spot lamp. It's impossible to tell how much power the PMA is actually putting out at that speed by looking at the lamp.
The specs are incomplete/bogus, too. A 22mph wind means nothing. You need the torque/rpm curve to determine blade size in a "22mph wind" that will spin the PMA at the required rpm to make "500 watts." You might need a gear/step pulley to make the correct rpm.
And then there's 500 watts at ? what ? voltage. Low voltage will require expensive fat wire and higher voltages may require transformers or an mppt to make efficient power transfers to your load/battery bank. Is the output ac or dc? So many important questions unanswered.
« Last Edit: October 14, 2009, 04:02:11 PM by dnix71 »
FishbonzWV
« Reply #3 on: October 14, 2009, 04:56:28 PM »
Ben,
I chuckle when I see people light a  bulb to show how much power is being produced. A bulb is a fixed resistive load. Battery charging is a different ball game.
It's probably wired in star.
My conversion, a 3/4 hp 4pole will do 22V @ 150 RPM In Wye. Delta is 12.8V @ 150 RPM.
If I had a halogen handy I would give mine a test.
Those are also on the US ebay.
« Last Edit: October 14, 2009, 04:56:28 PM by FishbonzWV »
H.F.Fisher 1925-2007
